Silence Please.
Silver
Zero distortion clarity and noise, so you get everything you want to hear, and nothing you don't.
Skip to product information
1 of 6
PMG Signature Preamplifier
Release Date 2025 TBD. Now Accepting $300 Preorder Deposits. MSRP: $8,999. This Product is Trade-in Eligible.
With unsullied acoustic transparency, the PMG Preamplifier delivers zero-distortion clarity, so you get everything you want to hear, and nothing you don’t.
The Paul McGowan Signature Preamplifier isn’t an evolution—it’s a revolution. It’s our flagship, the very best we know how to build, and the first product in 50 years to carry the name of our founder. It had to. This time, it’s personal. Born from a lifetime of relentless pursuit, this is the purest, most transparent conduit between music and emotion we’ve ever created. With a vanishingly low noise floor of -145dB—beyond the limits of human perception—it uncovers musical truth with explosive dynamics, infinite depth, and holographic imaging. Nothing we’ve built comes close. Once you hear it, there’s no going back. It’s not just a preamp. It’s a revelation.
Regular price $300.00 USD
Regular price Sale price $300.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    The Paul McGowan Signature Preamplifier is a bold leap beyond anything that’s come before. Its fully balanced circuitry delivers an unprecedented level of purity and control. With a dynamic range approaching 150dB—the difference between a single molecule of sound and standing beside a roaring jet engine—it achieves a level of sonic blackness almost no other design on Earth can touch. Transients explode with lightning speed, and its bandwidth stretches beyond 500kHz for limitless openness and realism. High-speed, zero-feedback Diamond buffers preserve every musical nuance, while a revolutionary film-capacitor power supply unleashes dynamics with astonishing grace. This is not refinement. This is reinvention. The PMG Signature is pure musical authority.
  • Application
    The preamplifier is the heart of any high-end system. Every note, every breath, every bit of music from your sources—DACs, phono stages, CD players—passes through it before reaching your power amp. It’s the final gatekeeper, and it better be right. The Paul McGowan Signature Preamplifier is the first product in 50 years to carry my name, and for good reason. It delivers complete control, ultra-low distortion, and total isolation between sources and amplification. With five identical balanced and single-ended inputs, all signals are converted to fully balanced and passed through our zero-feedback Class A Diamond buffers. Nothing is added, nothing taken away. This is where the magic happens.
    Technology
    The Paul McGowan Signature Preamplifier is a statement of what's possible when nothing is held back. Designed by Darren Myers and carrying the name of our founder for the first time in 50 years, this is the culmination of a lifetime of innovation. Fully balanced from input to output, every stage features zero-feedback Diamond buffers for unmatched speed, transparency, and control. A high-resolution stepped attenuator ensures precise volume with 1/10th dB channel accuracy, revealing microdynamics with lifelike precision.
    At its heart is a revolutionary power supply that eliminates traditional electrolytic capacitors, replacing them with long-life, sonically superior film capacitors. The result is lightning-fast transient response, deeper silence, and greater dynamic swing. Housed in a double chassis construction that shields against noise and interference, the PMG Signature achieves a noise floor of -145dB—so quiet it’s not there.
    What you hear is exactly what was recorded—nothing added, nothing taken away. No glare, no grain, no veil. Just the music, uncolored and alive. The PMG Signature is the finest preamplifier we have ever built.
    • CLASS A BALANCED ANALOG OUTPUT STAGE
    • STEPPED ATTENUATOR FOR LEVEL CONTROL
    • FILM CAP BASED POWER SUPPLY
    • HYBRID DESIGN
    • BALANCED XLR OUTPUT
    • BALANCED XLR INPUTS
    • FOLDED CASCODE ANALOG DESIGN
    • DARREN MYER'S DESIGN
    • HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
    • AMONG THE WORLD'S LOWEST DISTORTION AND NOISE
    • NO CAPACITORS IN OUTPUT SIGNAL PATH
    • FULLY COMPLEMENTARY DIFFERENTIAL DESIGN
    • THE BEST PREAMPLIFIER IN 50 YEARS
    1 of 13
    Specifications - PMG Signature Preamplifier
    Physical
    Unit Weight 30 lbs / 13.6 kg
    Unit Dimensions 14 3/4” x 17 1/2” x 4 3/8” (with feet)
    375 mm x 445 mm x 112 mm (with feet)
    Shipping Weight 34 lbs / 15.4 kg
    Shipping Dimensions 20 1/2” x 24” x 10”
    521 mm x 610 mm x 254 mm
    Power Requirements
    Input Power Auto Voltage: 120VAC or 230VAC 50 or 60Hz
    Power Consumption 18W
    Connectors
    Audio Inputs RCA / Single-Ended: 2 pair
    XLR / Balanced: 4 pair
    Audio Outputs RCA / Single-Ended: 2 pair
    XLR / Balanced: 2 pair
    Trigger Output 2
    USB For USB firmware update only
    Performance
    Max Gain 12.6dB
    Frequency Response 15Hz-150kHz, +/- 0.1dB
    Input Impedance 50K Ω RCA / Single-Ended
    100K Ω XLR / Balanced
    Bandwidth 5Hz-500kHz, -3dB
    THD < .0002% @ 1kHz, 1VRMS input
    THD+N < .0003% @ 1kHz, 1VRMS input
    IMD .0005% @ 1VRMS input, CCIF, 20kHz mean, 1kHz difference
    Crosstalk -135dB, One channel driven
    Output level 9VRMS Single-ended / 18VRMS Balanced @ 1% THD+N
    Output Impedance 100Ω
    Questions?
