PMG Signature Phono Preamplifier
Couldn't load pickup availability
Design
Application
Technology
PS Audio’s very first product in 1975 was a phono preamplifier that helped launch the company—and a movement toward better sound. Now, after 50 years of relentless innovation, we return to our roots with something truly extraordinary: the PMG Signature Phono Preamplifier. Designed by Darren Myers and bearing the name of our founder for the first time, this phono stage is unlike anything we—or anyone—have ever created. At its heart is a groundbreaking zero-feedback architecture, a first in PS Audio’s history. This unique topology allows for something remarkable: the true separation of vinyl surface noise from the music itself. Once you hear it, you can’t unhear it—and you’ll never go back. Surface noise floats in the background, untethered from the performance, leaving the music alive, present, and shockingly real. Adding to its revolutionary nature is an optional pure current-mode transimpedance input, ideal for low-output moving coil cartridges. This input requires no cartridge loading, offers unmatched transparency, and opens a window into your records that traditional voltage-input designs simply can’t match. With fully discrete Class A FET circuitry, massive headroom, and support for all cartridge types, the PMG Signature Phono Preamplifier is a triumph of analog engineering—and the finest phono stage we’ve built in our 50-year history. From the first needle drop, you’ll know: this is vinyl reborn.
Features
Specifications - PMG Signature Phono Preamplifier
PMG SIGNATURE PHONO PREAMPLIFIER |
Unit Weight | 30 lbs / 13.6 kg |
Unit Dimensions |
14 3/4” x 17 1/2” x 4 3/8” (with feet) |
Shipping Weight | 34 lbs (15.4 kg) |
Shipping Dimensions |
20 1/2” x 24” x 10” |
Color Options | Black Silver |
Voltage Options (Factory set only) |
Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
Fuses | 120V: T250V-1.6AH (1.6A Slow Blow) 230V: T250V-1AH (1A Slow Blow) |
Accessories Included | US (NEMA 5-15P) (100V/120V versions) Schuko (CEE7/7) (230V version) UK (BS1363) (230V version) Remote Control |
Audio Inputs |
MM or MC: XLR or RCA |
Audio Outputs | RCA (Unbalanced) 1 Stereo Pair XLR (Balanced) 1 Stereo Pair |
DC Trigger |
Input: 3.5mm (2) 5-15VDC |
Performance |
All measurements are with both channels operating, gain set to low, and balanced outputs. Input frequency is 1kHz. |
Input Loading | 47K, 1K, 470, 320, 200, 140, 100, 67, 40, 30, 16, 12 |
