Darwin Was Wrong
Silver
Not everything is an evolution. Sometimes there are paradigm shifts so monumental that the results are completely singular.
Skip to product information
1 of 6
PMG Signature 512 DAC
Release Date 2025 TBD. Now Accepting $300 Preorder Deposits. MSRP: $8,999. This product is Trade-In Eligible.
Meet the all new PMG Signature 512 DAC powered by PureStream DSD.
Digital audio was born in 1982 with the launch of the first CD player, and PS Audio didn’t miss a beat—we introduced the world’s first high-performance standalone D-to-A converter and never looked back. Now, after decades of innovation, we proudly unveil the PMG Signature 512 DAC. At its core is the PureStream DSD512 engine, converting any form of digital audio into a pure 8X DSD stream—no PCM, no decimation, no compromise. That stream feeds our SpectraWave 64-Tap Sequencer, lowering noise and distortion while perfectly time-aligning the signal. From there, it flows into a state-of-the-art, direct-coupled analog output stage. The result is breathtaking—fluid, natural, and as analog as it gets. With a built-in high-end streamer for seamless access to your music, the 512 is our best DAC ever. For the first time in PS Audio’s history, our founder’s name graces a DAC. Yes, it’s that good. And this time, it’s personal.
Regular price $300.00 USD
Regular price Sale price $300.00 USD
On Sale Sold out
call
TALK TO A HI-FI SPECIALIST
View full details
  • Design
    Designing the PMG Signature 512 DAC was never about meeting expectations—it was about redefining what a digital source could be. This is a radical departure not only from traditional PCM-based architectures but also from conventional DSD implementations and off-the-shelf chip solutions. At its core is our all-new PureStream DSD512 engine, a proprietary design that upsamples every input—PCM or DSD—to a native 8X DSD stream. That stream is then refined by our SpectraWave 64-Tap Sequencer, a precision digital filter engineered to eliminate jitter, reduce noise, and preserve every nuance of the music. The result is pure sonic truth, passed into a fully balanced, direct-coupled analog output stage. With galvanically isolated inputs, a built-in high-performance streamer, and precision analog volume control, the PMG 512 is not just a DAC—it’s the heart of a no-compromise reference system.
  • Application
    The PMG Signature 512 DAC is as versatile as it is revolutionary—and a major step above even the finest DACs we’ve ever built. Use it as a standalone directly into your power amplifier, thanks to its ultra-precise analog volume control, and experience purity, dynamics, and realism like never before. At its heart is PS Audio’s latest high-definition streaming module, fully galvanically isolated to eliminate noise and preserve absolute musical integrity. Whether paired with the PMG Signature Preamplifier for the ultimate reference system or run solo into your amp, the 512 delivers sound that is breathtakingly clear, natural, and alive. This isn’t just high-end performance. This is a whole new benchmark. The PMG Signature 512 DAC is music, uncompromised.
    Technology
    Think of the PMG Signature 512 DAC as the ultimate destination in digital audio—a no-compromise centerpiece for the most revealing high-performance systems. Whether your setup is purely digital or a hybrid of analog and digital sources, the 512 redefines what’s possible from a DAC. Built around our PureStream DSD512 engine and SpectraWave 64-Tap Sequencer, and featuring a fully balanced, direct-coupled analog output stage, the PMG 512 delivers sound with breathtaking realism, depth, and musicality. It supports I²S for a perfect connection to our top transport, and includes a world-class galvanically isolated streamer. Replace your DAC, your streamer—or even your preamplifier—and prepare to be stunned by the transformation. Rich. Pure. Effortless. The PMG Signature 512 DAC is the product of over fifty years of innovation and the first to carry the name of our founder. It’s not just the best DAC we’ve ever built—it’s the best DAC we know how to imagine.
    • CLASS A BALANCED ANALOG OUTPUT STAGE
    • FULL FUNCTION DAC
    • FIXED OR VARIABLE DAC MODE
    • ANALOG VOLUME CONTROL
    • BALANCED XLR OUTPUT
    • DIGITAL LENS TECHNOLOGY
    • PURESTREAM DSD 8X ENGINE
    • SPECTRAWAVE 64-TAP SEQUENCER
    • HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
    • SINAD EXCEEDING -100DB
    • NO TRANSFORMER IN OUTPUT SIGNAL PATH
    • QUAD RATE DSD
    • DSD DIRECT THROUGH I2S
    1 of 13
    Specifications - PMG Signature 512 DAC
    Physical
    Unit Weight 21 lbs [9.53 kg]
    Unit Dimensions 14 3/4” x 17 1/2” x 4 3/8” (with feet)
    375 mm x 445 mm x 112 mm (with feet)
    Shipping Weight 30 lbs [13.6 kg]
    Shipping Dimensions 20 1/2” x 24” x 10”
    521 mm x 610 mm x 254 mm
    Color Options Black
    Silver
    Power requirements
    Input Power Auto Voltage: 120VAC or 230VAC 50 or 60Hz
    Power Consumption 25W
    Digital audio inputs
    Inputs I2S (2), Coax (2), XLR Balanced (2), Optical, USB
    Sample Rates Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz
    S/PDIF (Coax and XLR): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64
    I2S:  PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256
    USB:  PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256.
    Analog Audio Output
    Connector RCA single ended or balanced, XLR balanced
    Output Level High, Maximum 4 VRMS Balanced
    2 VRMS Single Ended
    Output Impedance 100Ω / 200Ω
    Frequency Response 20-20KHz +/- 0.25dB
    THD+N @ 1KHz (full scale) < 0.002%
    Output Stage High-speed op-amp with discrete buffers.
    Data Handling
    Format PCM or DSD
    Sample Rate (PCM) 44.1kHz, 48.0kHz, 88.2kHz, 96.0kHz, 176.4kHz, 192kHz, 352.8kHz; 705.6kHz
    Word Length (PCM) 16b, 18b, 20b, 24b
    Data Rate (DSD) Standard (2.8MHz) or Double (5.6MHz) DoP as well as raw DSD on I2S and USB inputs
    Analog Conversion method DSD Ladder DAC at 5.6, 11.3 or 22.6MHz
    I2S Digital Input
    Connector HDMI
    Format PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs
    USB Digital Input
    Connector USB "B" Type
    Format PCM, DoP v1.1 (DSD over PCM), or Native DSD
    Transfer Mode Asynchronous
    Questions?
