Darwin Was Wrong
Not everything is an evolution. Sometimes there are paradigm shifts so monumental that the results are completely singular.
PMG Signature 512 DAC
Meet the all new PMG Signature 512 DAC powered by PureStream DSD.
Digital audio was born in 1982 with the launch of the first CD player, and PS Audio didn’t miss a beat—we introduced the world’s first high-performance standalone D-to-A converter and never looked back. Now, after decades of innovation, we proudly unveil the PMG Signature 512 DAC. At its core is the PureStream DSD512 engine, converting any form of digital audio into a pure 8X DSD stream—no PCM, no decimation, no compromise. That stream feeds our SpectraWave 64-Tap Sequencer, lowering noise and distortion while perfectly time-aligning the signal. From there, it flows into a state-of-the-art, direct-coupled analog output stage. The result is breathtaking—fluid, natural, and as analog as it gets. With a built-in high-end streamer for seamless access to your music, the 512 is our best DAC ever. For the first time in PS Audio’s history, our founder’s name graces a DAC. Yes, it’s that good. And this time, it’s personal.
Regular price
$300.00 USD
Regular price
Sale price
$300.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - PMG Signature 512 DAC
Physical | |
Unit Weight | 30.3 lbs [13.61 kg] |
Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
Shipping Weight | 40.3 lbs [18.3 kg] |
Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
Color Options | Black Silver |
Power requirements | |
Input Power | Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
Power Consumption | 30W |
Digital audio inputs | |
Inputs | I2S (2), Coax (2), XLR Balanced (2), Optical, USB |
Sample Rates | Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz S/PDIF (Coax and XLR): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64 I2S: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256 USB: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256. |
Analog Audio Output | |
Connector | RCA single ended or balanced, XLR balanced |
Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
Output Impedance | < 100Ω / 200Ω |
Frequency Response | 20-20KHz +/- 0.25dB |
THD+N @ 1KHz (full scale) |
<0.001% |
Output Stage | High-speed op-amp with discrete buffers. |
Data Handling | |
Format | PCM or DSD |
PCM Input |
Up to 768KHz 32 bits |
DSD Input | Up to DSD512 |
DSD Ouput | DSD128, DSD256, DSD512 (user selectable) |
Analog Conversion method | Single bit ladder DAC |
I2S Digital Input | |
Connector | HDMI |
Format | PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs |
USB Digital Input | |
Connector | USB "B" Type |
Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
Transfer Mode | Asynchronous |
Streamer | |
Connectivity |
Roon Ready |
Network Support |
WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) |
