PMG Signature 512 DAC
Couldn't load pickup availability
Design
Application
Technology
Think of the PMG Signature 512 DAC as the ultimate destination in digital audio—a no-compromise centerpiece for the most revealing high-performance systems. Whether your setup is purely digital or a hybrid of analog and digital sources, the 512 redefines what’s possible from a DAC. Built around our PureStream DSD512 engine and SpectraWave 64-Tap Sequencer, and featuring a fully balanced, direct-coupled analog output stage, the PMG 512 delivers sound with breathtaking realism, depth, and musicality. It supports I²S for a perfect connection to our top transport, and includes a world-class galvanically isolated streamer. Replace your DAC, your streamer—or even your preamplifier—and prepare to be stunned by the transformation. Rich. Pure. Effortless. The PMG Signature 512 DAC is the product of over fifty years of innovation and the first to carry the name of our founder. It’s not just the best DAC we’ve ever built—it’s the best DAC we know how to imagine.
Features
Specifications - PMG Signature 512 DAC
Physical | |
Unit Weight | 30.3 lbs [13.61 kg] |
Unit Dimensions | 14 3/4” x 17 1/2” x 4 3/8” (with feet) 375 mm x 445 mm x 112 mm (with feet) |
Shipping Weight | 40.3 lbs [18.3 kg] |
Shipping Dimensions | 20 1/2” x 24” x 10” 521 mm x 610 mm x 254 mm |
Color Options | Black Silver |
Power requirements | |
Input Power | Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
Power Consumption | 30W |
Digital audio inputs | |
Inputs | I2S (2), Coax (2), XLR Balanced (2), Optical, USB |
Sample Rates | Optical (TOSLink): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz and 96kHz S/PDIF (Coax and XLR): PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz and 192kHz; DoP64 I2S: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256 USB: PCM 16 and 24 bits at 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, 192kHz, 352.8kHz, and 705.6; DoP64, DoP128, DoP256, DSD64, DSD128, and DSD256. |
Analog Audio Output | |
Connector | RCA single ended or balanced, XLR balanced |
Output Level High, Maximum | 4 VRMS Balanced 2 VRMS Single Ended |
Output Impedance | < 100Ω / 200Ω |
Frequency Response | 20-20KHz +/- 0.25dB |
THD+N @ 1KHz (full scale) |
<0.001% |
Output Stage | High-speed op-amp with discrete buffers. |
Data Handling | |
Format | PCM or DSD |
PCM Input |
Up to 768KHz 32 bits |
DSD Input | Up to DSD512 |
DSD Ouput | DSD128, DSD256, DSD512 (user selectable) |
Analog Conversion method | Single bit ladder DAC |
I2S Digital Input | |
Connector | HDMI |
Format | PCM or DSD. DoP on all inputs as well as raw DSD on I2S inputs |
USB Digital Input | |
Connector | USB "B" Type |
Format | PCM, DoP v1.1 (DSD over PCM), or Native DSD |
Transfer Mode | Asynchronous |
Streamer | |
Connectivity |
Roon Ready |
Network Support |
WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) |
