PowerPlant 12
PowerPlant 12
Our most powerful compact AC regenerator, the P12 regenerates new, safe, and pure AC from your home's power outlets for breathtaking improvement.
The DirectStream Power Plant 12 takes your incoming AC power and regenerate new sine-wave-perfect, regulated high current AC power. In the process of regeneration any problems on your power line such as low voltage, distorted waveforms, sagging power and noise are eliminated. The results are both audibly and visually stunning when powering either audio or video products. Further, the level of protection afforded connected equipment is extraordinary. Feel 100% confident that a P12 will provide pure and safe power under any condition. Don’t starve your music or risk damaging your equipment. A P12 gives you greatly improved performance and safety from just plugging into the wall socket and far better dynamics, bass and a much bigger, open soundstage than any passive power conditioner on the market.
Regular price
$5,999.00 USD
Regular price
Sale price
$5,999.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - Power Plant 12
Environment Specification |
US/JP |
Europe/Asia |
Location | Indoor use only | Indoor use only |
Duty Cycle | Suitable for continuous operation | Suitable for continuous operation |
Moisture Sensitivity | Not sealed against moisture | Not sealed against moisture |
Operating Humidity | <80%rh | <80%rh |
Storage Temperature | -40C to +40C | -40C to +40C |
Operating Temperature | 0C to 40C | 0C to 40C |
Max Operating Altitude | 12,000’ (3500m) | 12,000’ (3500m) |
Electrical Supply Nominal Rating | 120V 15A 60Hz US 100V 15A 50/60 Hz JP |
230V 10A 50/60Hz |
Instrument Specification |
Unit Dimensions | 17” W x 14” D x 4” H (43cm W x 36cm D x 10.16 cm H) | 17” W x 14” D x 4” H (43cm W x 36cm D x 10.16 cm H) |
Unit Weight | 37 lbs ( 16.7kg) | 37 lbs ( 16.7kg) |
Shipping Dimensions | 24” x 21” x 10” ( 61cm x 53cm x 25cm) | 24” x 21” x 10” ( 61cm x 53cm x 25cm) |
Shipping Weight | 48 lbs (21.7kg) | 48 lbs (21.7kg) |
Nominal Input Voltage | 95 – 145 VAC | 200 –285VAC |
Maximum Continuous Load | 1000VA | 1200VA |
Maximum Peak Load | 3600VA | 3800VA |
Voltage Regulation | 0.5V | 1V |
Output Distortion (Resistive Load) | <0.5% | <0.9% |
Output Distortion (Reactive Load) | <0.5% 0.1% typical |
<0.9% 0.1% typical |
Output Impedance | <0.008 ohm | <0.008 ohm |
Noise Reduction | 100kHz – 2MHz >80dB | 100kHz – 2MHz >80dB |
Efficiency @1200 VA | >85% | >85% |
Input Frequency | 45 – 65 Hz | 45 – 65 Hz |
Under Voltage Limit | US - 90 V JP - 75 V |
174 V |
Over Voltage Limit | US - 144 V JP - 120 V |
275 V |
Energy Dissipation | 1020J | 1270J |
Peak Current Surge | 90,000A | 90,000A |
Max Surge Voltage | 6,000V | 6,000V |
Clamp Level | 340V | 800V |
DC Trigger Configuration | Tip Positive | Tip Positive |
DC Trigger Voltage | 5 – 15Vdc | 5 – 15Vdc |
Standby Power Consumption |
35 Watts |
30 Watts |
