BHK Signature Preamplifier
Preamplifiers are at the heart of any high-performance music system. They are the critical controlling interface between our sources of music and our loudspeaker chain. Most preamplifiers do a fine job of control and isolation, but only a rare handful make magic happen. Add the BHK Signature Preamplifier into your system and suddenly you are enveloped in a wealth of musicality you’ve not yet experienced: deeper, wider, sound staging, improved separation of instruments and voices, subterranean bass, extended highs, and an openness you're unlikely to have experienced without this instrument in the system.
Regular price
$3,499.00 USD
Regular price
$6,999.00 USD
Sale price
$3,499.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Design
Application
Technology
Features
Specifications - BHK Signature Preamplifier
Physical |
Unit Weight | 22 lbs [9.97 kg] |
Unit Dimensions | 17” x 14” x 4” [ 36cm x 43cm x 10cm] |
Shipping Weight | 31 lbs [14 kg] |
Shipping Dimensions | 20.5”x 24” x 10” [52cm x 61cm x 25cm] |
Power requirements |
Input Power | Model specific 100VAC, 120VAC, or 230VAC 50 or 60Hz |
Power Consumption | 60W |
Audio inputs |
Coaxial RCA single ended XLR Balanced |
5 5 |
Input Impedance Unbalanced (RCA) Balanced (XLR) |
33KΩ minimum 66KΩ minimum |
Sensitivity | Unbalanced 1.3V/33KΩ Balanced 1.3V/66KΩ |
Audio Outputs |
2 2 |
Analog Audio Output |
Output level | 4.0 Vrms |
Output Impedance | <100Ω |
Frequency Response 20-20KHz |
+/- 0.1dB |
THD&IM @ 1KHz (full scale) | <0.03% |
Bandwidth | -3dB 0.1Hz - 200kHz |
DC Triggers |
+12V | 2 |
Headphone Performance |
Output Power 300Ω 16Ω > |
>200mW 4.0 Watts |
S/N Ratio | >90dB (1KHz) |
THD & IM 1 volt out | <0.02% |
Output Impedance | <0.5Ω |
