BHK Mono 600 Power Amplifier Pair
Couldn't load pickup availability
The inner details
Design
Application
Technology
The importance of the power amplifier in the 2-channel system chain cannot be overstated, yet it's often overlooked. It's the rare few music lovers that truly appreciate the power amp's critical role in preserving music's nuanced details, because most amplifiers fail to preserve them. Overtones from plucked instruments, subtle cues defining placement, depth, soundstage width, and transient decays are often lost in the power amplifier. Suddenly revealed are the tiniest of details that now ring clear through the BHK, perfectly preserved through its low feedback, vacuum tube and MOSFET design. When it comes to musically controlling and powering loudspeakers, the BHK Signature 600 has no peer. The Signature 600 monoblock amplifier is a no holds barred upgrade from its series-mate, the BHK300. Its 1.6KVA power transformer is twice the size of the 300 and we didn't stop there. The 600's 300,000uF bank of low-ESR high-grade audio power supplies caps is double that of the 300 as are doubled the output MOSFETs producing some of the lowest output impedance and highest damping factors we have ever measured. The control this amplifier has over the music and the system is unrivaled.
Features
Specifications - BHK Mono 600 Power Amplifier
BHK Signature 600 Mono
Unit Weight | 108 lbs [49 kg] |
Unit Dimensions | 17.1” x 11.2” x 14” Chassis only. 17.5″ deep including connectors and handles |
Shipping Weight | 120 lbs [55 kg] |
Shipping Dimensions | 24”x 17” x 24” |
Color Options | Black Silver |
Voltage Options Factory set only |
Japan 100V North America 120V Europe/Asia/Australia/New Zealand 230V |
Mains Power Inputs | IEC C14 |
Fuse Compliment all Countries (internal) | 4 - 15A Fast Acting 5x20mm type F250V10AL |
Fuse Compliment Mains (back panel) | 100vac Countries 1 - 2 amp time-lag H-rated 5x20mm 1 - 12.5 amp time-lag H-rated 5x20mm 120vac Countries 1 - 2 amp time-lag H-rated 5x20mm 1 - 10 amp time-lag H-rated 5x20mm 230vac Countries 1 - 1.6 amp time-lag H-rated 5x20mm 1 - 8 amp time-lag H-rated 5x20mm |
Accessories Included | US (NEMA 5-15P) (all versions) Schuko (CEE7/7) (230V version) UK (BS 1363) (230V version) |
Audio Inputs | RCA (Unbalanced) XLR (Balanced) |
Speaker Outputs | Gold plated copper binding posts (2 pair per channel) |
Other | DC Trigger Input with pass through 3.5mm 5-15VDC |
Warranty | 3 years parts and labor on unit 1 year on vacuum tube |
Power Consumption |
@Ready | 75 Watts |
@Idle | 225 Watts |
@Rated power 8Ω | 950 Watts |
@Rated power 4Ω | 1500 Watts |
Signal |
Gain | 26.0dB/30.5dB +/-0.5dB selectable |
Sensitivity for rated output power of 600 watts into 8Ω | 3.5V/2.1V |
Noise | 100-20KHz <-100dBV |
Input impedance | Single Ended 100KΩ Balanced 200KΩ |
Output Impedance | <70mΩ (20-20KHz) |
Frequency Response | @2.8VRMS 10Hz – 20KHz +/- 0.1dB 10Hz – 100KHz +0.1/-3.0dB |
THD & IM |
1KHz, 1W/8Ω | <0.002% |
20-20KHz, 1W/8Ω | <0.01% |
1KHz, 200W/8Ω | < 0.01% (120VAC Mains input) |
1KHz, 400W/4Ω | < 0.02% (120VAC Mains input) |
Output Power |
Both channels driven 120vac mains, 1kHz, 1% THD |
8Ω | 600W minimum |
4Ω | 1000W minimum |
2Ω | Stable for musical transients |
