Skip to product information
1 of 29
Aspen FR5 Loudspeaker
The perfect size loudspeaker for any small to medium-sized room.
"The best speaker I've ever heard in this price range*"
The ground-breaking Aspen series of loudspeakers sets new standards for what is possible in home audio reproduction. Now, with the introduction of our full range 2-way stand mount speaker, the Aspen FR5, it is finally possible to bring the concert hall to any small to medium sized room.
The Aspen loudspeaker series represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a speaker that is easily driven with any decent power amplifier, and when not even the most advanced driver manufacturer’s products are good enough to meet our exacting standards, designing woofers, radiators, and tweeters from scratch. In all respects, the FR5 will transcend your expectations of what an affordable stand mount loudspeaker can do.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold, fits in any small to medium sized room, with bass that will astound you, the Aspen FR5 is a dream come true.
Regular price $3,499.00 USD
Regular price $0.00 USD Sale price $3,499.00 USD
On Sale Sold out
Trade-in
call
TALK TO A HI-FI SPECIALIST
View full details
The first reviews are in
From the very first showing of the FR5s at the Axpona HiFi show, reviewers and music lovers alike fell in love with them. See what Jay Lee of Jay's Iyagi on YouTube had to say in this video.
Prepare to be amazed
The Aspen FR5 stand mount loudspeakers are extraordinary performers delivering powerful and dynamic sound with extended bass even in larger rooms. Utilizing innovative new technologies like viscoelastic damping sheets between the bracing and cabinet side walls, a newly-designed 6.5-inch cast frame midrange/woofer made from Curv woven polypropylene, and a state-of-the-art air core and film cap crossover, the FR5 delivers the same quality of extraordinary musical realism as the larger Aspen Series models, in a compact design that fits easily into smaller and medium-sized rooms.
I was taken aback by what I heard
Hear what reviewer Jay of Jay’s Audio had to say about his first listen to the incredible Aspen FR5. Watch as he searches for the non-existent subwoofer on these powerful stand mount wonders.
  • Design
    The FR5 joins the ranks of a rare handful of 2-way full-range speakers that can honestly cover the frequency range of 35Hz to beyond 20kHz with grace, dynamics, slam, and low distortion—and work in most small to medium-sized room. Within moments of installing your new Aspen FR5 loudspeakers, you'll instantly be transported to a new level of musical ecstacy. What's captured on the disc is exactly what you'll hear with a greater resolution than most have ever experienced. Grace, beauty, PRaT, power, and a musicality that is rare amongst 5 figure offerings from other manufacturers await owners of the Aspen FR5. That this speaker is financially within anyone's budget makes it a miracle.
  • Application
    Loudspeakers are part of the family. With their presence, they grace our homes and living areas by bringing the joy of music into our lives. Unlike the electronics that drive them, most loudspeakers depend on proper placement and optimized room parameters to perform their best. The Aspen FR5, however, is designed to more easily fit into any living environment and perform at its best with a minimum of setup hassles and a maximum of options. While the FR5, like all high-performance speakers, appreciates some breathing room between them and the front wall, placement in the room for best performance is a snap. Using the included step-by-step guide and CD, setup, from unboxing to playing music, happens easily in a few short hours.
    Technology
    By far the most important piece in the HiFi chain is the loudspeaker. If the speaker cannot reproduce what it is fed from the electronic chain, the missing musical information is forever lost. To achieve all that music demands, over the years, loudspeaker designers have tried to leverage every trick in the book: electrostats for details, conventional drivers for dynamics, planars for transparency, ribbons, domes, horns, open baffles, bipoles, dipoles. The list is endless and the choices and their inevitable sonic compromises daunting. With close to 50 years under our collective belts, we at PS Audio are committed to designing the perfect loudspeakers for every application, room size, and budgets. In the Aspen series we start with the FR30, then move to the FR20, the FR10, and finally the FR5. Each is a full range state-of-the-art loudspeaker that covers the range of possibilities from small to large rooms and to meet every budget need. The FR5 will fit into every small to medium sized room and provide potent bass output and extension for a stand mounted speaker. For the upper end, the FR5 employs the same Aspen planar tweeter as found in both the FR20 and FR30. Without question, the Aspen FR5 is the perfect loudspeaker for any small to medium-sized room and, certainly, any budget. Why compromise? Go for the best.
    • FULL-RANGE 2-WAY SYSTEM
    • 83.5 dB SENSITIVITY
    • ONE 2.5" PLANAR RIBBON TWEETER
    • ONE 6.5" LOW DISTORTION HIGH EXCURSION WOOFER
    • ONE 6X9” HIGH EXCURSION PASSIVE RADIATOR
    • CURV (WOVEN, SELF-REINFORCED POLYPROPYLENE) CONE
    • THERMOSET FIBERGLASS RESIN FRONT BAFFLE
    • SMOOTH AND FULL OFF AXIS RESPONSE
    • ONE PIECE CABINET FOR EASY SETUP
    • EASY TO POSITION FOR BEST PERFORMANCE
    • CONSTRAINED LAYER DAMPED INTERNAL BRACING FOR LOW CABINET VIBRATION
    • CUSTOM FILM CAPACITORS & PREMIUM AIR-CORE INDUCTORS
    • MAGNETICALLY ATTACHED GRILLES
    1 of 13
    Specifications - Aspen FR5 Loudspeaker
    Color Options Satin White, Satin Black
    Enclosure Type Passive radiator (one 6x9” oval rear-firing)
    High Frequency Transducer 2.5” planar magnetic with Teonex diaphragm
    Low Frequency Transducer 1 x 6.5” woofers, cast frame, Curv woven polypropylene, advanced magnet structure
    Crossover Frequency 1750 Hz - Linkwitz-Riley 6th order acoustic
    Sensitivity (2.83V @ 1M) 83.5 dB
    Nominal Impedance 6 ohm (5.6 ohm minimum impedance)
    Recommended Amplifier Power 50-150W
    Frequency Response 35 Hz-20 khz (-6dB) half space, 30 Hz (-6 dB) in-room
    Dimensions (HxWxD)
    14.5" x 8" x 13" speaker only
    28.25" x 11.75" x 14” stand only
    Net Weight
    Speaker: 26.6 Ibs (12.1 kg) each
    Stand: 13.71b (6.2 kg) each
    • Mark Craven and Paul Miller, Hi-Fi News
      An ability to bring deep, controlled bass to
      your music listening could be considered
      the FR5’s calling card, but really this is a
      loudspeaker that excels with all manner
      of material.
      See More
    • Jay's Audio
      See More
    • Mad Audio
      Not too warm, not too analytical, not in your face, but perfectly balanced.
      See More
    • Enjoy The Music
      The PS Audio Aspen F5 monitor loudspeakers properly set up they can disappear into a wide-open immersive soundscape capable of both intimacy and large-scale contrasts.
      See More
    • John Brandon gearadical
      Overall, I loved the sound and testing out what warm even means. In the end, for me, it means the product is worth the price.
      See More
    • John E. Johnson Jr. Secrets of Home Theater
      Two of the most notable things about the sound of these speakers are the very nice planar-magnetic tweeter delivering a smooth, musical presentation, and the deep bass produced by the combination of the mid-woofer and passive radiator.
      See More
    • Kalman Rubinson Stereophile
      FR5s presented a credible, full-size, audible image of a Steinway D, up front between the speakers.
      See More
    • Jay's Audio Lab - Youtube
      They just completely vanish from the room. Some speakers take a lot of tinkering to make disappear. These 20 pound speakers didn't make me struggle at all.
      See More
    • Erin's Audio Corner
      Low distortion and good dynamic range
      See More
    • Maciej Stryjecki - HiFi and Music
      Few monitors will play as if a subwoofer was hiding behind the curtain.
      See More
    • PS Forum
      Remarkable. In my bit of a strange space, I can say, and after only 11 days, I find these speakers to be pretty remarkable. They are currently 23 inches from the front wall, 1-1/2 feet from the side walls, and just over 3 feet apart. Yet, they still are giving me a deep sound stage behind them.
      See More
    • PS Forum
      IMHO, this is the best speaker I have ever had in my setup. In short, tonality of both vocals and instruments is shockingly realistic; the detail is mind-blowing; the mid-range is superb, and the bass is tight I am playing a lot of my favorite music and am overwhelmed at how much music was previously missing. Chris, thank you for a super affordable speaker!
      See More
    • Robert Harley - The Absolute sound
      Best Sound (for the money): PS Audio Aspen FR-5 loudspeaker ($3000 per pair). This little standmount played way above its size and price, filling a large room with a big soundstage and deep bass.
      See More
    • Lawrence D. Devoe - TheaterByte
      The PS Audio FR5 speakers present a small but mighty choice for buyers whose rooms don’t quite fit this speaker’s larger siblings. In reality, the FR5 shares the same high frequency transducer as its bigger brothers and will fit comfortably in larger rooms with little audible compromise.
      See More
    • Feversound.com
      Combined with the long-stroke voice coil design and a large magnet system, this compact driver can handle loud playback with extended excursion while keeping distortion low.
      See More
    • Steve Guttenberg Audiophiliac
      There's something about the FR5 that encourages me to play the field in terms of music genres.
      See More
    Questions?
