Aspen FR30 Loudspeaker
Absolute Sound Magazine's Ultra High-End Loudspeaker of the year!
Our goals for the FR30 were to design and build a state-of-the-art full-range loudspeaker with extraordinarily low distortion, effortless reproduction, seamless tonality, and exquisite beauty.
Our highest expectations have been exceeded.
The Aspen FR30 represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a near-flat impedance curve for driving the speakers with any power amplifier, and when not even the most advanced driver manufacturer's products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, the FR30 will transcend your expectations of what it means to be called a reference loudspeaker.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold. The Aspen FR30.
Grilles now available in Grey and White – Learn more
Regular price
$34,999.00 USD
Regular price
Sale price
$34,999.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Literally Nothing Like It
If you want to make uniquely beautiful art, you have to start by creating your own paints. That’s why for the FR30’s, the decision to custom build every component was an easy one. The result is something that is truly a one-of-a-kind listening experience.
Design
Application
Technology
Features
Specifications - Aspen FR30 Loudspeaker
Color Options | Pearl White, Sable Black |
Enclosure Type | Two piece – Sealed upper cabinet mid-tweeter module, Passive radiator lower cabinet (4 10” side-firing passive radiators) |
High Frequency Transducer | 2 x 2.5” planar magnetic with Teonex diaphragm |
Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
Low Frequency Transducer | 4 x 8” woofers, cast frame, aluminum cone, 12lb advanced magnet structure |
Crossover Frequency | 400 Hz, 2500 Hz – LR4 |
Sensitivity (2.83V @ 1M) | 88 dB |
Nominal Impedance | 4 ohm (3.6 ohm minimum impedance) |
Recommended Amplifier Power | 100-600W |
Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
Dimensions (HxWxD) | 60.5” x 16” x 25.75” with base (10” width not including base) |
Net Weight | 230 lbs (104.5 kg) |
