Aspen FR20 Loudspeaker
The perfect size loudspeaker for any room
The ground-breaking Aspen series of loudspeakers sets new standards for what is possible in home audio reproduction. Now, with the introduction of the smaller FR20, it is finally possible to bring the magic of Aspens into more people’s homes.
The Aspen loudspeaker series represents the culmination of 50 years of industry experience; learning in intimate detail what works and what does not; what it takes for a loudspeaker to disappear and leave only the magic of the music; designing a no-compromise phase-correct crossover; constructing a cabinet that does not color the sound; crafting a near-flat impedance curve for driving the speakers with any power amplifier, and when not even the most advanced driver manufacturer’s products are good enough to meet our exacting standards, designing woofers, radiators, tweeters, and midranges from scratch. In all respects, both the FR30 and FR20 will transcend your expectations of what it means to be called a reference loudspeaker.
No longer do you have to compromise.
Breathtaking to listen to, beautiful to behold, and compatible with any room size the Aspen FR20 is a dream come true.
Grilles now available in Grey and White – Learn more
Regular price
$22,999.00 USD
Regular price
Sale price
$22,999.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Reference performance for any room
The Aspen FR20 loudspeaker is the next in line from the ground-breaking Aspen FR30. The FR20 shares with the FR30 the same planar ribbon and ultra-linear woofer technologies that produce extraordinarily low distortion, thunderous bass response while maintaining its ability to sonically disappear. The FR20 is perfect for small to medium sized rooms and budgets and will stand as a true reference loudspeaker in any system. Come learn more about this extraordinary loudspeaker.
Design
Application
Technology
Features
Specifications - Aspen FR20 Loudspeaker
Color Options | Pearl White, Sable Black |
Enclosure Type | Passive radiator (two, 10” side-firing passive radiators) |
High Frequency Transducer | 2.5” planar magnetic with Teonex diaphragm |
Mid Frequency Transducer | 10” planar magnetic with Teonex diaphragm |
Low Frequency Transducer | 2 x 8” woofers, cast frame, carbon fiber Rohacell sandwich cone, 12lb advanced magnet structure |
Crossover Frequency | 400 Hz, 2500 Hz – Linkwitz-Riley 4th order acoustic |
Sensitivity (2.83V @ 1M) | 87 dB |
Nominal Impedance | 4 ohm (3.5 ohm minimum impedance) |
Recommended Amplifier Power | 50-300W |
Frequency Response | 23Hz-20kHz (-6dB) half space, 20 Hz (-6dB) in-room |
Dimensions (HxWxD) | 50.5” x 16” x 18.75″ |
Net Weight | 133 lbs (60.3 kg) |
