AirLens - Refurbished
The AirLens™ interface brings perfection to streaming
Streaming audio via Roon or other services like Qobuz, Tidal, and Spotify offers millions of titles at the touch of a finger. Unfortunately, connecting your sensitive DAC to the noise generated by computers, routers, NAS, local networks, and modems via either WiFi or Ethernet cable is not a great-sounding solution to bringing high-performance audio into your listening environment. The PS Audio AirLens™ completely eliminates the problems of noise, jitter, and EMI influences through complete galvanic isolation and perfect reclocking of the digital audio signal. You’ve not yet heard how great streaming can sound until you experience audio through the AirLens.
You have 14 calendar days to audition a Refurbished item from the date you received it. For more information on PS Audio Refurbished units click here.
Regular price
$1,499.00 USD
Regular price
$1,999.00 USD
Sale price
$1,499.00 USD
Unit price
per
Couldn't load pickup availability
TALK TO A HI-FI SPECIALIST
Updating the AirLens
Our step-by-step guide to updating firmware over-the-air for the AirLens Streamer. Please use DIP Switch 7 in the UP position to update the main firmware. Use the same process with DIP Switch 7 in the DOWN position to update the streamer firmware.
Design
Application
Technology
Features
Specifications - AirLens
General |
Unit Weight | 4.8 lbs [2.2 kg] |
Unit Dimensions | 10” x 7” x 1.5” [ 25.4cm x 17.8cm x 3.8cm] |
Shipping Weight | 6.8 lbs [3.1 kg] |
Shipping Dimensions | 5.8” x 13.6” x 11.6” [14.6 cm x 34.6 cm x 29.4 cm] |
Color Options | Black, Silver |
Voltage Options | Universal |
Mains Power Input | 100-240VAC 50-60Hz |
Power Consumption | 5W Typical/10W max |
Accessories Included | Power cord |
Input | 10/100/1000 Ethernet or 2.4 & 5GHz WIFI |
Audio Outputs | 12s, S/PDIF Coax |
Features |
Audio Interface | • PCM: Up to 352.8kHz/32 • Native DSD up to DSD256 (I2S output) • DoP (DSD over PCM) up to DSD128 (Coax output) |
Network Support | • WiFi: IEEE 802.11 b/g/n/ac (2.4 & 5GHz dual band) • 10/100/1000 Ethernet |
WiFi Setup | • WPS |
Connectivity | • DLNA 1.5 & UPnP AV 1.0 Digital Media Renderer • Spotify Connect • Roon Ready • TIDAL Connect • Qobuz Connect • Dropbox (through Roon) • MQA |
