Disappearing act
Disappearing act
It’s the moment we all chase. You cue up the music, settle into your chair, and suddenly… the speakers are gone. Not turned off, not quiet—just gone. What’s left is the illusion: musicians suspended in space behind the speakers, a stage you can see with your ears.
That disappearing act is one of the most powerful experiences in high-end audio—and one of the easiest to achieve if you understand how to do it. And while yes, phase coherence matters, and flat off-axis response helps too, the real key is something most people overlook: setup.
You can have the world’s best speakers and amps, but if your setup’s off you won’t get there. Imaging collapses. The center gets blurry. The stage shrinks. You may not know what’s wrong, but your brain does. The illusion just doesn’t land.
That’s why I wrote The Audiophile’s Guide: The Stereo and The Listening Room. They’re step-by-step tools to help you get your system tuned to the room, and your room tuned to the music. We’ve helped thousands of people experience their gear for the first time—not by upgrading, but by setting it up right.
If you haven’t gone through the process yet, it’s time you did. Because when everything locks into place—speaker position, toe-in, listening height, symmetry, reflection control—that’s when the magic happens.
And the best part? You already own the gear. You just need to let it disappear.
Disappearing act
Disappearing act
