Back to The Daily Tip
Tip Number 22: Clean Records Are Not Optional
You drop the needle on a favorite LP. The notes are familiar. But between them? Something’s riding shotgun. A soft crackle. A faint hiss that seems baked into the silence. The edges of transients might feel softened, as if detail is being delivered under glass. You’ve likely checked the setup—alignment, VTF, even the stylus itself. Still, it sounds like the music’s been thumbed through.
Could be the surface isn’t dirty. The grooves might be.
What to Do
Go deeper than the brush. Even a pristine-looking record—new or vintage—can carry mold release compounds, oils, and embedded dust that won’t lift with a sweep of carbon fiber. Try a proper wet clean: enzymatic fluid followed by vacuum removal, or an ultrasonic bath if you’ve got access. Manual vacuums like Record Doctor V, paired with surfactant cleaners like Audio Intelligent #15 or MoFi’s Enzyme Plus, can get you most of the way there. Clean before the first play. Store in anti-static inner sleeves. And avoid DIY alcohol blends unless you’re sure they won’t harden the very vinyl you’re trying to rescue.
Here’s Why That Works
Grooves aren’t smooth—they’re terrain. The stylus doesn’t just skim; it hikes. And any residue in that path becomes a distortion engine, injecting noise and dulling the trail. When the walls are clean, the stylus tracks tighter, friction drops, and energy reappears where it once felt drained. Transients might crack sharper. Reverb tails may drift a little longer before vanishing.
The hiss you’re hearing? It might not be noise. It might be detail you’re not hearing yet. Clean grooves don’t just remove something—they restore something. The sense that what’s hiding behind the music has finally stepped forward.
