Issue 31 • Free Online Magazine
Issue 31 FEATURED
More Q & A on Getting Better Sound
Continuing with our questions & answers series, I have two that have always caused some contention.  In that respect, I hope you find them interesting:
Why you should be sour on a “wide sweet spot” for serious listening with two-channel playback
Hey, we might as well get this topic kicked off with a bang…
A “wide sweet spot” is almost like having your own harmonic distortion generator! With stereo sound, there’s simply no way a serious listener should be satisfied to sit more than a foot away from the “equal path length intersection” (center point) of sound from a pair of loudspeakers. Inter-channel phase and timing information will have been badly compromised, destroying instrumental timbres.
How is it that many audiophiles will accept only phase and time-aligned loudspeakers and then they expect to sit off the acoustic center point, totally destroying the inter-channel phase/time information?
Look at it this way…
First, since you probably know this stuff, please forgive the simplified averaged wavelengths, but for purposes of illustration, let’s assume that an 1100 Hz tone (or harmonic) has a length of about 12 inches. Then 550 Hz is almost 2 feet in length (from the top of the sound-wave crest to the top of the next). And 2 kHz is almost 6 inches in length, 4 kHz is 3 inches, etc.
Now imagine that a female vocalist is recorded with her image centrally located in the stereo stage. If you sit two feet off-center, any fundamental notes and their harmonics from 500 Hz and above have been altered, some dramatically, some slightly. This is audible, and it’s depressingly measurable!
Before we examine the disastrous effects of stereo comb filtering (what I’m euphemistically calling harmonic distortion), let’s look at what’s happened to our stereo imaging…
OK, let’s say that, by sitting to the left of center, you’re now about two feet closer to the left speaker than you are to the right one. Imagine a centrally recorded image that is reproduced at equal volume (amplitude) from both speakers in order to give the illusion of a precise center image.
Without going too far into recording techniques or speaker dispersion patterns, a panned mono center image (such as is produced in a studio) may appear to have shifted left somewhat, while a center image recorded from a stereo pair of microphones seems to “stay put” a little better. But these are phantom images at best, lacking in the ultimate richness of tone and body. Here’s why…
It’s not the potential “image wander” that’s troublesome. It’s the harmonic distortion! (Technically, it’s not distortion, but the alteration of harmonic relationships.) The positive cycle (top of the wave crest) of an 1100 Hz overtone arrives at your ear from the (closer) left speaker before it does from the right one. Due to the resulting phase cancellation from different arrival times, there’ll be an audible—and very measurable—change at that frequency (or harmonic overtone).
Should the distance be equivalent to a half-wavelength further (6 inches), then that particular overtone (harmonic) will arrive exactly out of phase. And you know how your stereo plays less bass when the speakers are out of phase? Well, the effect is exactly the same— a reduction in level at that particular frequency.
Here’s a simple test for you:
Put on a Sheffield or other disk that contains pink noise in both channels (pink noise is best, because it contains equal energy per octave, just like music).
Now, as the cut of pink noise is playing, while sitting in the center (equidistant to the speakers) position, slowly move your head to the left or right. That huge change in mid/treble tonal balance is exactly what happens when you sit off axis.
And because the wavelengths vary according to frequency, the varying time arrivals of harmonics also produce an unpredictable cancellation effect (well, it is predictable in that it’s never a good thing). And a ‘wide sweet spot’ isn’t really so sweet…
 Why is this important?
The unique relationships of vocal overtones are different for each voice & instrument. For example, the first overtone (harmonic) may be 87.3% of the fundamental, the second just 48.1%, the third 54.7%, etc.
The exact relationship of these overtones (their relative strength, compared to the fundamental) is the identifying “genetic code” of the instrument/voice. It turns out that all instruments and voices have their own particular set of harmonic ratios.
That’s how we know how to differentiate two different instruments that are playing exactly the same note—let’s say A (440 Hz). It’s how an original Guarneri will be chosen over a “replica”—it’s all in the “tone”—which is actually the harmonic—or overtone—structure.
So, if you’re sitting where the path lengths are significantly unequal from the left and right speakers, you are absolutely guaranteed to hear shifts in the harmonics, meaning that an instrument or voice will not sound exactly as it should. This is not just some subjective acoustic theory. It’s not only audible; it’s also shockingly measurable in your room at your listening seat when compared to a nearby seat!
The sad fact is, you’ve just altered your system’s harmonic relationships. So why did you buy all that stuff with “vanishingly low distortion” if you’re going to introduce a far worse version by not sitting in the center point where the path lengths are equal? Incidentally, this is an incontrovertible law of physics that is part of the good—and the bad—of stereophony. It has no bearing whatsoever upon sitting off – center in the concert hall, because the sound is not being reproduced from a pair of widely spaced loudspeakers which are subject to severe comb-filtering due to varying time arrivals at your head.
From a perfectionist’s standpoint, it doesn’t matter if your loudspeakers produce a smooth response off-axis. Even in an acoustically dead room, the varying wavelengths from two loudspeakers – when received at a listening position off the acoustic center – will always produce uneven response on centrally recorded images (actually all images, but it’s easier to think about the centrally recorded image for the purposes of illustration).
Now that I’ve told it like it is, I’ll also admit to having absolutely wonderful experiences listening to music while others have occupied the best seat. If a system has dynamics, if it’s effortless, if it at least starts out being pretty accurate tonally, then it can be quite listenable off-axis. Just remember that the phantom image produced off -axis in stereo is only an approximation.
Sweet, it ain’t!
If you’re past 50, can you really hear well enough to care about your sound quality?
I’ll never forget these intertwined events. It was in the early 1980s, and I was recording the Alabama Symphony for the Birmingham National Public Radio affiliate.
Several leading union musicians (from the Symphony tape committee) and the conductor would visit my shop one night each month. I’d play back the master recordings that I had recently made of concerts that were to be broadcast. Their job was to pick the best performance. Then I would prepare the broadcast master from my 30 I.P.S. analog master.
I came to know and to spend some time around the conductor. I’d say he was in his middle ’70s at that time. In our informal meetings, he’d have a problem with discrimination, which is common for older folks. In this case, discrimination is the term for being able to listen to someone and understand him while others are talking at the same time.
Before I tell you my main point, you need to know one more thing: It’s REALLY LOUD on stage with a full orchestra when it’s playing power music. I once went out onstage while doing a test recording during a dress rehearsal for Gustav Holst’s The Planets. As luck would have it, it was during “Uranus,” one of the loudest sections.
I had measured the peak sound pressure levels in the front rows of the audience. I knew they were about 95-100 dB. But up on stage, standing next to the conductor with all the brass and percussion wailing away, I was shocked at how loud it was. It felt like my hair was being blown back like that old Maxell tape ad!
Of course, this conductor – who has been exposed to these incredible sound levels for 50 years – is bound to have significant hearing damage. Add to that the age factor, and this man should have been lucky to hear an ambulance siren!
During our listening sessions at my shop, he always picked up on problems, often before the much younger musicians (with technically better hearing). Furthermore, in the middle of a Beethoven Symphony #6 rehearsal, I saw him tell a second violinist several rows back to retune. On more than one occasion, he’d have to call somebody on a blown entrance when there was a full orchestra wailing away!
It always amazed me that he could hear so precisely during the playback sessions and during the rehearsals. My point is that age, and even exposure to lifelong loud levels, seems not to be the only indicator as to whether a trained listener can still hear.
For example, I often sit with younger men and women, teaching them about sound, or just kicking back listening to music. I’m older than they , but I can reliably hear things that they miss entirely.
One more point – I have found that if a music lover can enjoy live music, then he or she can enjoy reproduced music as well.  Don’t worry if you’re past 50. It just means that you’re experienced!
Note, these answers are edited versions of topics from Get Better Sound and the companion Quarter Notes newsletters. You can also read Jim’s work at his website. www.getbettersound.com
More from Issue 31
View All Articles in Issue 31
#232 What came first: Art or Music? A Conversation With Artist Jose Acosta by Joe Caplan Jul 06, 2026 #232 Blow By Blow: The Jeff Beck Story: An Insightful Book About a Guitar Icon by Ray Chelstowski Jul 06, 2026 #232 Creed Over Camaraderie? by B. Jan Montana Jul 06, 2026 #232 Chronicles of a Sound Pilgrim at the 2026 Montreal Audiofest by Hugues Morin Jul 06, 2026 #232 The Vinyl Beat: Summer Grooves by Rudy Radelic Jul 06, 2026 #232 Hibbing Hillbilly Dylan's Acoustic Rock by Wayne Robins Jul 06, 2026 #232 Quad Quads and Plasmatronics Tweeters: An Extraordinary System Comes to Life by Frank Doris Jul 06, 2026 #232 In Praise of Live Music, Once Again by Ted Shafran Jul 06, 2026 #232 Allnic Audio’s L-9000 Preamplifier: Design and Engineering Innovation by Howard Kneller Jul 06, 2026 #232 “Best Of” Lists and Rage Bait: Enough Already by Frank Doris Jul 06, 2026 #232 Quick Takes: Bud Shank, Paulo Almeida, Jakob Dreyer, Tim Eriksen and Peter Irvine by Frank Doris Jul 06, 2026 #232 My Impressions of AXPONA 2026, Part 2 by Frank Doris Jul 06, 2026 #232 How to Play in a Rock Band, 25: Encounters With Famous Musicians, Part Three by Frank Doris Jul 06, 2026 #232 Budgets, and Systems From Small to Outrageous by Paul McGowan Jul 06, 2026 #232 PS Audio in the News by PS Audio Staff Jul 06, 2026 #232 Hand It Over by Frank Doris Jul 06, 2026 #232 Difference of Opinion by Peter Xeni Jul 06, 2026 #232 Wabi-sabi Tree by James Schrimpf Jul 06, 2026 #231 Piano Prodigy Jude Kofie Releases His Debut Album On Octave Records by Frank Doris Jun 01, 2026 #231 Underappreciated Artists, Part Two: City Boy by Rich Isaacs Jun 01, 2026 #231 Music and the Art of Creation: Talking With Saxophonist Rob Scheps by Joe Caplan Jun 01, 2026 #231 How to Play in a Rock Band, 24: Further Adventures at the 2026 Montauk Music Festival by Frank Doris Jun 01, 2026 #231 Courtney Barnett: Creature of Habit by Wayne Robins Jun 01, 2026 #231 Angine de Poitrine: Interstellar Guitar Rock Saviors Headed for Late-Night TV Pop Stardom? by Mark Lepage Jun 01, 2026 #231 My Impressions of AXPONA 2026, Part One by Frank Doris Jun 01, 2026 #231 2026 La Jolla Concours d'Elegance: Another Aesthetic Feast by B. Jan Montana Jun 01, 2026 #231 Country Music Icon Jo Dee Messina’s Bridges: A New Beginning by Ray Chelstowski Jun 01, 2026 #231 The Luxury Dispatch Hosts a Video Podcast With Ken Kessler by Ken Kessler Jun 01, 2026 #231 The Vinyl Beat: Tracking in the Motor City by Rudy Radelic Jun 01, 2026 #231 Lots of Fun With DSP: The Ferrum Audio WANDLA DAC and Its Tube Mode by Frank Doris Jun 01, 2026 #231 From The Audiophile's Guide: Digital Source Components and Streaming Audio by Paul McGowan Jun 01, 2026 #231 Onkyo’s Monster M-510 power amplifier by The Staff at Just Audio Jun 01, 2026 #231 PS Audio in the News by PS Audio Staff Jun 01, 2026 #231 Naming Convention by Peter Xeni Jun 01, 2026 #231 Les Invisibles by Frank Doris Jun 01, 2026 #231 Wildlife Scene by James Schrimpf Jun 01, 2026 #230 Camaraderie by B. Jan Montana May 04, 2026 #230 AXPONA 2026: A Family Gathering by Paul McGowan May 04, 2026 #230 Pianist Ryan Benthall Explores Jazz Realms and Far Beyond With Divine Sky by Frank Doris May 04, 2026 #230 The Vinyl Beat in AXPONA-Land by Rudy Radelic May 04, 2026 #230 Teddy Thompson’s Musical Growth Deepens With Never Be the Same by Ray Chelstowski May 04, 2026 #230 More Fun in the Sun: Florida Audio Expo, Part Two by Frank Doris May 04, 2026 #230 CanJam NYC 2026 Show Report: Heady Sound, Part Two by Frank Doris and Harris Fogel May 04, 2026 #230 Sonic Youth On Murray Street by Wayne Robins May 04, 2026 #230 Graffeo Coffee: A Symphony of Sensory Experience by Joe Caplan May 04, 2026 #230 The Saul Authority: The Story of Hi-Fi Pioneer Saul Marantz by Olivier Meunier-Plante May 04, 2026 #230 How to Play in a Rock Band, 23: Encounters With Famous Musicians, Part Two by Frank Doris May 04, 2026
Sweet, it ain’t!
