Copper Magazine · Issue 41 · A free PS Audio publication
Issue 41 FEATURED
LP Playback: Is It Really Reference-Quality?
Is it truly superior if it has not one, but two iterations of eq; an extra gain stage; a signal-to-noise ratio that is definitely not so superior; inner-groove distortion; variable performance; and it is especially prone to errors in set-up?
The reason I ask is that – despite the issues above and many more below – many LP lovers present the sound from their LPs as the ultimate in reference quality playback.  But is it?
Please note – this article is NOT about vinyl not being worthwhile or anything comparable. But hey – since it’s most likely that a number of Copper readers are vinylphiles, I thought it’d be a good idea to make them angry. NOT!   ☺
However, I do want to say a few things that might make some readers unhappy. So please consider this a thought piece – another viewpoint.
Cringeworthy?
In my travels, attending and participating in shows, dealer events, and countless voicing sessions, including those going back for over 35 years, I have almost never encountered a turntable that I thought was set-up as well as it could have been. That’s right, I’ve hardly ever heard one that I thought was delivering all of the music!
This includes all audiophiles’ turntables, as well as those set up by most dealers, manufacturers, & reviewers, and yes – tt set-up gurus.  Although, to be fair, I’ve not heard a complete turntable set-up by all of the acknowledged gurus, including Michael Fremer.
I realize that somewhere in audioland, there have to be some turntables that are performing as well as they should.  It’d just that I haven’t encountered them.
The bad news is that – in my experience (over a thousand tts), almost all of them could have been better. Some ‘tables needed just a bit of help – and sadly, some required a lot.  The good news is that — at least in recent times (thanks to more knowledge & equipment available to effect proper mechanical set-up) — typically, it didn’t take much time nor effort to bring about a significant improvement.
When I had the opportunity to experiment, it always proved to be the case that I could make that vinyl-playing-rig sound better. And it often didn’t take long to do it.
Maybe that’s why I cringe when I see audiophiles claiming their ‘tables sound so good.  They might sound OK, but are they playing at the level that they could?  Probably not.
To be fair, who knows what our vinyl replay is really supposed to sound like?  The truth is, none of us have that information, and (with a few notable exceptions) that may include the mastering engineer.
Turning it up to 11
1) Most of us fancy ourselves as purists who wouldn’t sully our rigs with EQ – analog or digital.  I can recall very few audiophiles ever answering YES to this question: “Would you use a full-range equalizer in your system?”
Yet every time we play an LP, the sound has gone through not one, but two levels of EQ! First, the RIAA mastering curve is introduced to the LP itself, and then we must play the LP back through a phono preamp stage that contains (hopefully) the mirror image EQ to get us back to “flat” response.
This situation assumes precisely mirror-imaged curves (recording & playback), which, truth be told, occurs less frequently than we might think.  Different labels introduce slightly different emphasis.  Earlier, pre-RIAA recordings used their own “in-house” EQ curves. So we have two levels of the dreaded EQ, and they may not be accurately EQ’d for some of our recordings anyway.
2) Most audiophiles pay attention when they see a design that has managed to dispense with an extra gain stage, but for some reason, we give the additional – relatively high-gain – phono-stage a pass.  Additionally, especially if we have moving-coil cartridges, then we may opt to purchase a high-quality outboard phono-preamp.  Same EQ concern, only now we’ve introduced even more variables – probably even more gain required, plus we’ve added additional cables and connections into the equation.  Of course, this is totally against what we attest to believe is best – fewest gain stages, fewest connections & cables, but, hey, this is analog, so fuggedaboutit!
3) Sadly, no engineering breakthroughs have occurred that significantly reduce inner groove distortion – it’s simply a part of the vinyl LP package.
4) You do know that no two phono cartridges ever sound the same, right?  Question – is the one that you own the best of its breed?  Have you compared it to other cartridges of the same manufacturer and model number?  Just asking… ☺
5) The varying thickness of LPs will mean that you often will not be playing your LPs at the optimum SRA. In other words, variable performance is guaranteed. Are you going to readjust for every record, or simply live with the resultant degradation in sound?  There is a way to address this issue, but do you know about it?
6) As someone who has made hundreds of master recordings – both 30 IPS analog and digital – this needs to be said: The tape master ALWAYS makes the LP sound broken – lacking in dynamics, presence & tone. As an example, consider the well-deserved reputation for excellence that Peter McGrath’s digital master recordings always receive at various audio exhibits.
No turntable – at any price – can bridge the inherent gap between the master tape and the mastered LP. It is HUGE – and that comparison assumes the use of a correctly set-up turntable/phono-stage rig.
7) These days, anyone who is willing to go to the effort and expense of playing vinyl LPs should have managed to properly execute the basic mechanical aspects of setting up their turntable.  And now, there are a number of useful tools that make the mechanical aspect of the task achievable.  When I mention that I still encounter turntables that fall short, it’s rarely from the mechanical set-up side – overhang, azimuth, etc.  That’s good news indeed.  The one mechanical aspect that often can still be addressed is turntable isolation.
8) One more mechanical aspect that can sometimes be addressed would be the variable-ratio-of-moment-of-inertia of the tone-arm counterweight and cartridge (when the option is available). An important aspect, yet rarely discussed.
9) The areas that seem to consistently benefit from a bit more work are phono cartridge loading (for moving coils), vertical tracking force, VTA/SRA, and anti-skate.  I do NOT feel that gauges can get this job done – you need to LISTEN to the effects of all of them.  And they are inter-related – as is room temperature(!)
10) If the main system hasn’t been dialed in to properly “play the room” how can the vinyl lover possibly know if his/her adjustments are going in the right direction?  This reminds me of a few RoomPlay Reference clients who come here, and at some point, ask to hear their CD, because – as they say – they “know it”.  IMO, they almost certainly do NOT know it, but I try not to say that – at least not right away.
11) Finally, need I mention LP surface noise?
A finyl word
When a digital system is done right, or at least pretty well, the music can flow and pluck your heartstrings.  Although I love to listen to my vinyl, I haven’t in several years, preferring for a number of reasons to pursue making my digital archives the medium of choice.
FWIW – many RoomPlay Reference visitors who come here assume – and often mention – that one reason the sound is so listenable here is that I am playing “Hi-Rez” digital, but no, it’s simply 16/44.1 material.  This news usually comes as a big surprise to them.
No one ever complains or expresses a desire to hear vinyl.  Most say it is the best sound they ever heard, and more than a few are vinyl enthusiasts.  Maybe it’s just an unusually polite crowd, who knows?
It would be nice if some audiophiles would stop and think before declaring that their vinyl playback is the superior/more accurate/higher resolution music playback medium.  Maybe it is – IF they have overcome the 11 issues listed above.
Finylly, many of the current digital product offerings are definitely worth the effort of exploring, if for no other reason than archiving your beloved analog LPs. And yes, in some cases, better sound.
There, I said it.
Surely, everyone agrees, right?
[This is an edited/updated version of an article that Jim wrote for  Copper #26. That piece provoked so much comment that I asked him to take another look at the subject of vinyl playback. You can also read more of Jim’s writings here. —Ed.]
More from Issue 41
View All Articles in Issue 41
#236 Magic Boy: The Jimi Hendrix Experience, Live and Rediscovered by Frank Doris Nov 02, 2026 #236 The Great Rhythmic Divide: Composer David Chesky Asks, Why Doesn't the Symphony Orchestra Groove? by David Chesky Nov 02, 2026 #236 More Record Reviews: Roni Eytan’s Microtonal Harmonica, Jane Ira Bloom, and a Frank Zappa Freak Out by Frank Doris Nov 02, 2026 #236 An Album of Inviting Beauty: Goodnight Moon from Acoustic Eidolon, And an Interview With the Artists Who Created it by Frank Doris Nov 02, 2026 #236 Never Ignore Your Inner Voice by B. Jan Montana Nov 02, 2026 #236 Composer Joseph Bertolozzi Uses Bridges, Structures and the World as Musical Instruments, Part One by Joe Caplan Nov 02, 2026 #236 Transmission: A Powerful Horn-Loaded Album from the Huntertones by Ray Chelstowski Nov 02, 2026 #236 Les Quatre Saisons du Québec: a New “Four Seasons” on Tour and on ATMA Classique by Robert Schryer Nov 02, 2026 #236 From The Audiophile's Guide: A Glossary of Terms for Today's Audio Systems, A – M by Paul McGowan Nov 02, 2026 #236 From The Listening Chair: An Introduction to Audiophile Tweaks by Howard Kneller Nov 02, 2026 #236 The Vinyl Beat Grew Two Inches Since October! by Rudy Radelic Nov 02, 2026 #236 How to Play in a Rock Band, Part 29: Figuring Out How to Play the Songs by Frank Doris Nov 02, 2026 #236 The Return of the Residents: Eskimo is On the Road by Wayne Robins Nov 02, 2026 #236 PS Audio in the News by PS Audio Staff Nov 02, 2026 #236 The People Who Make Audio Happen – Fun In Las Vegas at…CES 2026? by Harris Fogel Nov 02, 2026 #236 The Forms of Things Unknown by Frank Doris Nov 02, 2026 #236 Prophetic by Peter Xeni Nov 02, 2026 #236 Here's Looking at You, Kid by Rich Isaacs Nov 02, 2026 Favorites From T.H.E. Show SoCal 2026 by Cam Martin Oct 05, 2026 #235 Singer/Songwriter John David Schrader: On the Need to Create, Part Two by Joe Caplan Oct 05, 2026 #235 A Life in High-End Audio: The Roy Hall Interview, Part Two by Frank Doris Oct 05, 2026 #235 Grammy-Winning Producer, Songwriter, and Guitarist John Leventhal Goes Instrumental With National Drift by Ray Chelstowski Oct 05, 2026 #235 From Swimming Pool to New Listening Room—to Founding an Accidental Audio Company by Gilles Laferrière Oct 05, 2026 #235 The Vinyl Beat’s Size Matters Edition by Rudy Radelic Oct 05, 2026 #235 The Sublime Complexities of Nature by B. Jan Montana Oct 05, 2026 #235 How to Play In a Rock Band, 28: Growing Older and Dealing With It by Frank Doris Oct 05, 2026 #235 Young Rascals: From Bar Band to Stardom by Wayne Robins Oct 05, 2026 #235 Duncan Sheik: In Memoriam by Ray Chelstowski Oct 05, 2026 #235 From The Listening Chair: The Meze Audio 105 Silva Headphones by Howard Kneller Oct 05, 2026 #235 Checking Out Some NOLA Loudspeakers – and Some Thoughts About Audio Writing by Frank Doris Oct 05, 2026 #235 The Kanazawa Phonograph Museum: Music from a Time Capsule by Sebastian Polcyn Oct 05, 2026 #235 PS Audio in the News by PS Audio Staff Oct 05, 2026 #235 From The Audiophile’s Guide: Making the Most Critical Choice by Paul McGowan Oct 05, 2026 #235 Evolutionary Growth by Frank Doris Oct 05, 2026 #235 Speed Racer by Peter Xeni Oct 05, 2026 #235 Happy Halloween! by James Schrimpf Oct 05, 2026 #234 A Life in High-End Audio: The Roy Hall Interview, Part One by Frank Doris Sep 07, 2026 #234 Jason Greenlaw Offers His Personal Perspective on Jazz Guitar in Vantage Point by Frank Doris Sep 07, 2026 #234 Transcendent Phoenix: Lucina Yue Brings the Ancient Konghou Into Modern Times by Frank Doris Sep 07, 2026 #234 We Must All Follow Our Bliss by B. Jan Montana Sep 07, 2026 #234 How to Play in a Rock Band, 27: Leveling Up by Frank Doris Sep 07, 2026 #234 Ross Valory: Traveling Into New Musical Territory With All of the Above by Ray Chelstowski Sep 07, 2026 #234 Singer/Songwriter John David Schrader: On the Need to Create by Joe Caplan Sep 07, 2026 #234 The People Who Make Audio Happen: More From T.H.E. Show SoCal 2026 by Harris Fogel Sep 07, 2026 #234 The Vinyl Beat Digs Into the Gadget Box by Rudy Radelic Sep 07, 2026 #234 The Rolling Stones: Foreign Tongues Spoken Loud by Wayne Robins Sep 07, 2026 #234 Musical Moments by Rich Isaacs Sep 07, 2026
Cringeworthy?
Turning it up to 11
A finyl word
There, I said it.
