The Regen is trying to generate a USB signal that's clean enough that the DAC's USB PHY (the PHYsical layer, the part that drives and receives the signals over the wire) doesn't have to "work as hard" and hence doesn't add as much noise to the power supply. To go at higher and higher speeds it takes more signal conditioning. These days many PHYs dynamically change their parameters to better send and receive signals and using those features can use significant current. The Regen tries to take on the work (with the resultant changing current draws and resultant noise) on the input side so the DAC's PHY doesn't have to and then the Regen sends a much more consistent quality signal so that the DAC doesn't make noise in itself trying to accommodate a signal that's changing quality. Like jitter it's another way that a relatively little known effect can end up being manifest noise.I cannot tell you with any honesty that what I was listening to is in any way better, worse or the same as these other USB devices: the Jitterbug John Atkinson reported in print, Michael Lavorgna and John Darko on the web, or the Uptone Regen, or Schiit Wyrd, but from all accounts, adding one of these devices can bring wonderful improvements for little money. The technology I auditioned last week set me on my rear and removed my socks in one swell foop. Easily as big as the difference between a S/PDIF input and the Network Bridge and perhaps even bigger. I haven't yet taken measure of the size, but oh my gosh, this requires more investigation and, perhaps more importantly, it shall never leave my system, despite the fact I haven't much need of longer USB cables. Perhaps most significant to me is the nature of the change itself: simply ground breaking. As I wrote yesterday the new USB interface removes whatever was blocking the three dimensional origami shapes of instruments in the music. I have never heard anything quite like it.
Join the Conversation
Share your thoughts below and get our latest posts in your inbox
