It is important on a Windows computer to install the PS Audio driver before connecting the PS Audio DAC. During the install process you will be asked to connect the intended DAC for the PC to recognize. If this process has not been followed, it may be necessary to uninstall the USB driver and start over according to these instructions.
The install should finish correctly.
© 2023 PS Audio, Inc.
How to solve in Mac?
Hi
I have a PWD II with firmware upgrade to 2.4.6
I followed these steps to install the USB driver. worked smoothly on window 7 home version PC.
But on window 8.1 PC, PWD II freezes and causes errors to
other audio devices installed. Some are removed, some says malfunctions
this happens if PWD II is connected to the PC during Window shut down and restart
but if PWD II is detached from PC before Window shut down and before window restart,
and then re-connect the PWD II to the PC during running Window would work
this is a bother to me specially on my brand new PC running window 8.1 enterprise version on 5th generation i5 chipset, two SSD hard drives.
I hope there is a quick fix from ps audio
