<strong>The importance of the audio interconnect cables in a high-end audio system cannot be overstated. With Stellar, as with any high-performance equipment, the quality of the audio interconnect conductors and the effectiveness of the noise reduction system is critical. AQ Mackenzie analog interconnects were chosen as the perfect match for Stellar.</strong>
The AQ Mackenzie interconnects are part of AudioQuest's River Series featuring advanced geometry, solid Perfect-Surface Copper+, Hard-Cell Foam insulation, Triple Balanced geometry, and a Carbon-Based 3-Layer Noise-Dissipation System (NDS). AQ Mackenzie were chosen to match Stellar's natural sonic character, resulting in an optimum system synergy. Enjoy the perfect match of Stellar and Mackenzie from AQ.
$228.73
The PS Audio Home Experience
Hear it. Live with it. Love it.
There’s no better way to know if new gear truly belongs in your system than to hear it at home — in your room, with your music.
With the PS Audio Home Experience, you can audition any new product for a full 30 days in the comfort of your home.
Let it burn in, settle into your system, and decide at your own pace.
If it’s not the perfect match, simply return it — no questions asked.
Trading up? No worries. Keep your current gear until you decide, then send back whichever you’re not keeping.
Experience music the way it was meant to be heard — right where you live.
Design
The AQ Mackenzie interconnects employ Triple-Balanced Geometry which uses a separate ground-reference conductor, so the cable's shield is never used as an inferior conductor. Whether prepared with RCA or XLR plugs, the cable's three conductors ensure that the positive and negative signals have equally superior, low-distortion conducting paths. Whereas almost every other “balanced” cable uses its shield as the ground reference, AQ Triple-Balanced cables use a separate dedicated shield that is only connected on one end. Couple Triple Balanced Geometry with Mackenzie's Solid Surface Copper+ conductors for superb, low-distortion performance.
Application
In a PS Audio Stellar System, AQ Mackenzie balanced (XLR) or single-ended (RCA) interconnects tie every piece of audio gear, from the Stellar S300 Stereo or M700 Monoblock amplifiers, to the Stellar GainCell DAC and everything in between. The extraordinary shielding and superior conductor geometry will bring new life to your system and put a smile on your face.
Hard-Cell Foam Insulation
Hard-Cell Foam (HCF) Insulation ensures critical signal-pair geometry. Any solid material adjacent to a conductor is actually part of an imperfect circuit. Wire insulation and circuit board materials all absorb energy (loss). Some of this energy is stored and then released as distortion. Hard-Cell Foam Insulation is similar to the Foamed-PE used in our more affordable Bridges & Falls cables, and is nitrogen-injected to create air pockets. Because nitrogen (like air) does not absorb energy and therefore does not release any energy from or into the conductor, distortion is reduced. In addition, the stiffness of the material allows the cable's conductors to maintain a stable relationship along the cable's full length, producing a stable impedance character and further minimizing distortion.
Solid Perfect Surface Copper+ Conductors
Solid conductors prevent both electrical and magnetic strand-to-strand interaction, major sources of distortion. Surface quality is critical because a conductor can be considered as a rail-guide for both the fields within a conductor, and for the magnetic fields that extend outside the conductor. The astonishingly smooth and pure surface of all AudioQuest’s Perfect-Surface metals nearly eliminates harshness and greatly increases clarity compared to lesser materials. Extremely high-purity Perfect-Surface Copper+ further minimizes distortion caused by grain boundaries, which exist within any metal conductor, nearly eliminating harshness and greatly increasing clarity compared to OFHC, OCC, 8N and other coppers.
Features
5 key features
SILVER-PLATED PURPLE COPPER CONNECTORS
SOLID PERFECT-SURFACE COPPER+ CONDUCTORS
CARBON BASED 3-LAYER NOISE DISSIPATION SYSTEM
COLD-WELDED CONNECTIONS
HARD CELL FOAM INSULATION
Reviews
0 reviews
No reviews yet for this product.
Write a Review
Share your experience with AudioQuest Mackenzie Analog Interconnects
Thank You!
Your review has been submitted successfully. We appreciate you taking the time to share your experience.
Review
Loading review...
Questions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
