PMG SIGNATURE PHONO PREAMPLIFIER |
| Unit Weight | 30 lbs / 13.6 kg |
| Unit Dimensions |
14 3/4” x 17 1/2” x 4 3/8” (with feet) |
| Shipping Weight | 34 lbs (15.4 kg) |
| Shipping Dimensions |
20 1/2” x 24” x 10” |
| Color Options | Black Silver |
| Voltage Options (Factory set only) |
Auto Voltage: 120VAC or 230VAC 50 or 60Hz |
| Fuses | 120V: T250V-1.6AH (1.6A Slow Blow) 230V: T250V-1AH (1A Slow Blow) |
| Accessories Included | US (NEMA 5-15P) (100V/120V versions) Schuko (CEE7/7) (230V version) UK (BS1363) (230V version) Remote Control |
| Audio Inputs |
MM or MC: XLR or RCA |
| Audio Outputs | RCA (Unbalanced) 1 Stereo Pair XLR (Balanced) 1 Stereo Pair |
| DC Trigger |
Input: 3.5mm (2) 5-15VDC |
Performance |
All measurements are with both channels operating, gain set to low, and balanced outputs. Input frequency is 1kHz. |
| Input Loading | 47K, 1K, 470, 320, 200, 140, 100, 67, 40, 30, 16, 12 |
PMG Signature Phono Preamplifier
Release Date 2025 TBD. Now Accepting $300 Preorder Deposits. MSRP: $8,999. Receive up to $3,000 when you trade in your Stellar Phono
Talk to a Hi-Fi Specialist
Call 1-800-PSAUDIO
Home Audition Made Easy
There's nothing like hearing new gear in the comfort of your own system. With PS Audio's Home Audition program, trying out a brand new couldn't be easier. Simply place your order and we'll ship it to you—free of charge. Live with it for up to 30 days and discover if it's everything you hoped for. If it's not the perfect fit, no worries—we'll cover the return shipping and issue a full refund. No risk, no pressure, just music the way you want to hear it.
Design
Application
Overview
A revolutionary new design
An inside look
Features
12 key featuresCLASS A BALANCED ANALOG OUTPUT STAGE
ZERO FEEDBACK FOLDED CASCODES
FIXED AND VARIABLE LOADING
BALANCED XLR OUTPUT
70dB ULTRA LOW NOISE GAIN .15mv CARTRIDGES
2x INPUTS FOR 2x TONEARMS
TRANSIMPEDANCE INPUT
HIGH-CURRENT OVERSIZED ANALOG POWER SUPPLY
DISCRETE FET DESIGN
NO CAPACITORS IN OUTPUT SIGNAL PATH
CLASS 'A' ANALOG CIRCUITRY
DIAMOND BUFFERS THROUGHOUT
Reviews
0 reviewsNo reviews yet for this product.
Specifications
Technical detailsQuestions?
Need help right now?
💬 Try our Virtual Audio Specialist! Get instant answers about products, setup, and technical questions. Just click the chat icon in the lower right corner.
If that doesn't work for you, feel free to use this form below, or call a real Audio Specialist at 800-PSAUDIO (800-772-8346), Monday through Friday, 9am to 5pm MST.
