Call Us: 720-406-8946
DirectStream P20 Power Plant
Reference standard AC power delivery and protection
Built in Boulder
All units hand-made to order in Boulder, Colorado
Demanding systems require remarkable power. The DirectStream P20 Power Plant is our finest expression of the art of delivering protected, pure, regulated, distortion-free AC power. With peak power levels of 3600 watts, no equipment can tax the mighty P20. Finally, your most coveted components have the opportunity to unleash their full potential, no longer hindered by dynamic drops in AC caused by the unavoidable resistance of the miles of wiring between you and the power station. DirectStream P20 regulates both long-term fluctuations and peak dynamic without deviation, ensuring a solid foundation from which to build a state-of-the-art system. Its low output impedance and unhindered AC delivery are equivalent to less than 50 feet of 12 gauge wire connected directly to your city power source without the connecting miles of wire, the many transformers, and the multiple neighbors weakening and contaminating your power. The most demanding music systems require nothing less than the P20.
More Product Details »
Built to order in Boulder, CO. Your unit will ship within 7 business days.
Product Description
The DirectStream P20 is our most powerful AC regenerator ever with 2000 watts of pure regenerated power, enough for a single product or an entire system. The massive P20 is our finest expression of the art of pure power delivery. And the first US unit to accept both 20 amp and 15 amp power cables. Regardless of incoming power quality the P20 outputs clean, protected, low impedance, regulated power you can count on for the most demanding systems in the world.
Don’t starve your music. A P20 gives you improved dynamics, far better bass and a much bigger, open soundstage. Take one home and try it today.
This product qualifies for our risk free in-home trial in the continental United States when purchased directly from PS Audio.
  • Built in Boulder
  • 2000 VA output
  • Passively cooled
  • 40% more power
  • 3X lower impedance
  • 16 outlets US
  • 15 amp AC input US
  • 20 amp AC input US
  • 120 volt regulated US
  • Range 95 – 145 VAC US
  • 13 EU/AU/GR/UK outlets
  • 10 amp AC input EU/AU/GR/UK
  • 230 volt Regulated EU/AU/GR/UK
  • Range 200 –285VAC EU/AU/GR/UK
  • 100% regenerated AC
  • MultiWave
  • Pure Sine Wave
  • Integrated oscilloscope
  • THD meter
  • Improvement meter
  • Power meter
  • Control over the web
  • Adjustable output voltage
  • Color touchscreen
  • Field upgradable
  • 105 pounds boxed
  • 17W x 11H x 14D
Environment Specification
LocationIndoor use onlyIndoor use only
Duty CycleSuitable for continuous operationSuitable for continuous operation
Moisture SensitivityNot sealed against moistureNot sealed against moisture
Operating Humidity<80%rh<80%rh
Storage Temperature-40C to +40C-40C to +40C
Operating Temperature0C to 40C0C to 40C
Max Operating Altitude12,000’ (3500m)12,000’ (3500m)
Electrical Supply Nominal Rating120V 15A 60Hz US
100V 15A 50/60 Hz JP
230V 10A 50/60Hz
Instrument Specification
Unit Dimensions17” W x 14” D x 11” H (43cm W x 36cm D x 27.9 cm H)17” W x 14” D x 11” H (43cm W x 36cm D x 27.9 cm H)
Unit Weight96 lbs ( 43.5kg)96 lbs ( 43.5kg)
Shipping Dimensions23” x 22” x 17” ( 58cm x 55.8cm x 43 cm)23” x 22” x 17” ( 58cm x 55.8cm x 43cm)
Shipping Weight105 lbs (47kg)105 lbs (47kg)
Nominal Input Voltage95 – 145 VAC200 –285VAC
Maximum Continuous Load2000VA2000VA
Maximum Peak Load3600VA3600VA
Voltage Regulation>1V>1V
Output Distortion (Resistive Load)<0.5%<0.5%
Output Distortion (Reactive Load)<0.5%<0.5%
Output Impedance<0.005 ohm<0.005 ohm
Noise Reduction100kHz – 2MHz >80dB100kHz – 2MHz >80dB
Efficiency @1500 VA>85%>85%
Standby Power Consumption
Input Frequency45 – 65 Hz45 – 65 Hz
Under Voltage LimitContinuous -10% of setting 15 sec duration -15% of settingContinuous -10% of setting 15 sec duration -15% of setting
Over Voltage LimitContinuous 5% of setting 15 sec duration 10% of settingContinuous 5% of setting 15 sec duration 10% of setting
Energy Dissipation2040J5040J
Peak Current Surge180,000A180,000A
Clamp Level340V775V
DC Trigger ConfigurationTip PositiveTip Positive
DC Trigger Voltage5 – 15Vdc5 – 15Vdc
Want more product details?
