Quibbles and Bits
    Roll Over, Beethoven
    Issue 57
    If you were a professional orchestra conductor – or even a professional orchestra – it would behoove you to take steps wherever appropriate to promote the public perception of your musical qualities and talents.  As a conductor, if your profile rises you will be retained to conduct ever more prestigious orchestras, on an ever widening basis.  As an orchestra, you will attract higher profile conductors, more discerning musicians, and wider touring opportunities.  And with a bit of luck, more lucrative recording contracts – although, sadly, such days are coming rapidly to an end, if they haven’t already ended.
    One of the most established methods of raising one’s profile is to perform the major orchestral warhorses.  That way you get to lay down a body of work that can be compared not only to your peers, but also to the greats and not-so-greats who have come before.  Ideally, you want to lay down a body of recorded performances for posterity, for the cognoscenti to dissect and compare with the great reference recordings of note.
    Orchestral warhorses traditionally don’t come any more major than Beethoven.  There is hardly a conductor or orchestra around that hasn’t either laid down, or wanted to lay down, a marker in the form of a Beethoven Cycle – a cohesive set of performances of all nine of Beethoven’s symphonies.  In recorded format alone there are hundreds of these complete cycles.  I myself must have at least eight or nine.  Any conductor on a long-term appointment with an orchestra will traditionally be itching to embark on a Beethoven Cycle once he feels he has got the orchestra playing the way he wants.  And audiences tend to want it too.
    Why Beethoven?  After all, Brahms is pretty popular; Tchaikovsky and Sibelius too.  What makes a Beethoven cycle the ne plus ultra?  Well, the reasons are complicated and profound, and whole books have been written on the subject.  But in summary, Beethoven’s symphonies lend themselves perfectly as a vehicle for interpretive examination.  They are tightly structured – thematically, harmonically, and tonally.  Beethoven revolutionized the symphony as we understand it today.  He transformed it from a glorified sonata to a major compositional undertaking which thoroughly expresses a set of particular musical ideas in a comprehensive and structured manner.  Beethoven established the symphony as the ultimate vehicle of expression of a composer’s musical vocabulary, and transformed it into a format which would be considered the cornerstone of most composers’ eventual legacies for the next 150 years.
    He took it in new directions too … consider the utterly astonishing discordant outburst which occurs about 8½ minutes into the first movement of his 3rd Symphony, written as early as 1804.  It was an extraordinarily radical device (although one to which Beethoven himself, most curiously, never returned), which wouldn’t reappear in the mainstream musical lexicon for another 80-odd years.  Consider also the revolutionary 5-movement tone poem that is the 6th Symphony – the term “tone poem” itself didn’t even come into existence until after Beethoven’s death.  And of course we can’t ignore the 9th symphony whose revolutionary elements included a choir and vocal soloists (and much else besides), and which was written when the composer was all but totally deaf.  Sure, Mozart wrote symphonies, and laid the structural groundwork upon which Beethoven built his edifice.  But Mozart penned over 40 of ’em before dying at 32, of which only a handful can be thought of as ‘major works of great substance’.  Haydn cranked the handle too, churning out over 100 symphonies.  After Beethoven, though, everything changed.  A symphony was now a statement piece, a signature work by the composer.
    Arguably, nobody after Beethoven ever mastered the command of the symphonic format so completely (even as they continued to push the boundaries).  Take the famous first movement of the fifth symphony: DA-DA-DA-DAAAAH!  Beethoven took a trivially simple musical motif and asked what can we do with this?  Over the course of just seven minutes he showed exactly what can be done with it.  He played it slow and fast, high and low.  He inverted it.  He played it as a question, and as an answer.  He expanded it into phrases and contrasted it with a more elaborate melodic line.  He wandered from key to key, using the motif to punctuate the changes.  By the end of the seven minute movement he had neither short-changed us by a single note, nor over-stated his case.  We feel we have heard all there is to be said about DA-DA-DA-DAAAAH.  It is close to sublime perfection.
    Since the dawn of the recording age, the Beethoven Cycle, whether in the recording studio or the concert hall, has stood as the standard against which every conductor and orchestra has inevitably been measured.  But something strange has happened over the course of the last 20 years.  Beethoven has gradually been dumped in favor of Mahler.  No longer do conductors and orchestras feel the need to be validated by their Beethoven Cycles; it is now the Mahler Cycle against which they increasingly prefer to line up to make their mark.  The reasons are both simple and complicated, starting with the fact that a Mahler Cycle is nearly three times as lengthy as a Beethoven Cycle thereby providing a lot more music to get your teeth into.
    First of all, there are so many exemplary Beethoven Cycles out there that a new conductor coming to the cycle must wonder what is left for him or her to contribute to the discussion.  Secondly, there seems (to this listener at least) to be a convergence of style around the interpretive genius of Carlos Kleiber, with so many recent cycles clearly being heavily influenced by Kleiber’s truly legendary recording of the 5th with the Vienna Philharmonic.  Third, a Mahler cycle represents a serious challenge to the orchestra itself, exercising its players’ technical chops in a more demanding manner than does the Beethoven cycle.  Fourth, of course, are the interpretive challenges of the Mahler Cycle, and these are compelling indeed.
    Whereas a Beethoven Cycle requires the conductor to work within a highly formalized musical structure, allowing (even mandating) the form itself to be the major actor in holding the central elements of the performance together, with Mahler the form, while more elaborate, is at the same time much looser and more nebulous, easier seen from 30,000 feet than from 30 feet.  Indeed, much has been made of the airy notion that Mahler’s symphonies can be viewed individually as movements within some sort of greater symphonic whole.  Whereas with Beethoven, form is an attribute of the individual piece – even of the individual movement – with Mahler form can be interpreted across symphonies.  A conductor’s interpretation of Mahler’s 2nd, for example, must arguably inform his interpretation of the 3rd, something that makes relatively little apparent sense in the context of, say, Beethoven’s 5th and 6th symphonies.
    Mahler’s symphonies are built upon incredible layers of emotional complexity, which go far beyond mere programmatic expression.  Like actors performing Tennessee Williams’ “A Streetcar Named Desire” a conductor directing a performance of a Mahler symphony teeters on the edge of a razor blade risking failure to convince on one side, and gauche vulgarity on the other.  It is so, so hard to do, and few succeed convincingly.  It is tempting to approach these symphonies as being overtly programmatic, especially as the composer does indicate programmatic themes in most of them, sometimes explicitly, sometimes indirectly.  But for the most part they fail to respond well to a formally programmatic treatment, the possible exceptions being the overarching themes of redemption and resurrection in 2nd and 8th symphonies (which are more themes than programmes per se).  The payload from a Mahler symphony is inevitably delivered more emotionally than intellectually … or at least on significantly less of an overtly intellectual basis than with Beethoven.  We respond to Beethoven with our heads, but to Mahler with our hearts.
    Therein lies both the appeal and the immense challenge in conducting Mahler.  Whereas with Beethoven the challenge is heavy on the musical and technical aspects, with Mahler the weight is on the emotional aspect in harness with the vision to hold together and unite an uncaged beast which is apt to wander off in unexpected directions.  Not only are these challenges appealing to modern conductors and orchestras alike, but the appetite of the public to consume Mahler is apparently insatiable.  Modern concert hall audiences can’t get enough of it.  Not only that, they are far more knowledgeable and demanding of a Mahler performance than they ever were of Beethoven.  So as a conductor you are going to be more exposed with Mahler – if I am trying to appeal to your intellect I can get away to a certain extent with telling you how good it was, but if I’m trying to appeal to your heart only you can know the extent to which I was successful (even as my Maestro’s ego fails to permit me to acknowledge that).
    Finally, there is no Kleiber looming over today’s putative conductors of Mahler.  Not even close.  There was a time when it was obligatory to genuflect toward’s Bernstein’s benchmark recordings, and in truth ol’ Lenny played a significant role in the rehabilitation and elevation of Mahler’s reputation to the position it occupies today.  But, like a Magnum of Chateau Latour 2010, these incredible symphonies probably have another 50 years of development left in them before the interpretive well will start to run dry.  Today, there are very few new Mahler recordings that don’t have at least something interesting going for them, and there are a number of marvelous cycles already in play.  Which is the best?  Well, there are as many opinions on that as there are people with opinions.  Me, I kind of like Michael Tilson Thomas and the San Francisco Symphony, at least until I listen to one of the others … like Inbal’s unexpectedly powerful cycle with the Tokyo Metropolitan.  And since I have about 150 recordings of Mahler Symphonies that’s a lot of chopping and changing.
    So, roll over, Beethoven … and tell Mahler the news!  But in the next edition of Copper it’ll be a new Beethoven cycle rather than a Mahler cycle I’ll be talking about.
    Leave a Reply
    Also From This Issue
    Made By Hand
    As a late Boomer (as well as a late bloomer)…
    Show Report: Axpona 2018
    Normally, I’d think twice about visiting Chicago in April—winter has…
    Guitar Influences, Part 1: Mike Bloomfield
    I have been asked on several occasions to write about…
    The Sea and Cake
    Misheard lyrics are an age-old, unavoidable problem in rock music…
    Subscribe to Copper Magazine and never miss an issue.
    Stop by for a tour:
    Mon-Fri, 8:30am-5pm MST
    4865 Sterling Dr.
    Boulder, CO 80301
    1-800-PSAUDIO
    Join the hi-fi family
    Stop by for a tour:
    4865 Sterling Dr.
    Boulder, CO 80301
