Trio P-200 Stereo Preamplifier
Awards
Stereo Products > Trio P-200 Stereo Preamplifier
Starting at just $995.00!
  • Gain Cells
  • Remote Control
  • 3 RCA inputs
  • 1 XLR input
  • XLR balanced output
  • RCA output
  • Large high current power supply
  • Affordable
  • No attenuator loss
  • Variable gain preamplifier
  • handles any source material
  • Basic, clean exceptional sounding
  • Inputs selectable from front panel
  • Inputs selectable from remote
The P200 Stereo Preamplifier is our most affordable stereo preamplifier ever. At just $995, this is a killer piece that has zero sonic compromises.
Based on our revolutionary new Gain Cell technology, the P200 preamplifier does not attenuate the incoming source signal and thus degrade it. Instead, inside the P200 is a unique variable gain amplification stage that allows the user to adjust the gain via the front panel control or the supplied remote control, without attenuating the signal. This is the cleanest and sonically superior method of controlling gain to your amplifier.
The P200 features three single ended RCA inputs and a balanced XLR and single ended RCA output to connect to your power amplifier.
The P200 is a basic design in terms of features, but holds nothing back in terms of performance. A real killer piece.
Download the Manual: Trio P-200 Preamplifier Manual
