Quintessence Power Center
Awards
Power Products > Quintessence Power Center
Starting at just $999.00!
  • Harmonic distortion analyzer
  • AC voltage meter
  • Remote control
  • Real surge protection
  • Nano Crystalline filters
  • New "super" filter inside!
  • Unimpeded AC power flow
  • 10 Power Port AC receptacles
  • Solid aluminum chassis
  • Over under voltage protection
  • Solid copper delivery system
  • Delayed, switched outlet choices
  • Real sonic improvements
  • Best filter performance
  • Cleans AC into the audio region
  • Complete surge and spike protection
  • Low resistance AC path
  • Superior noise reduction
  • Delayed turn on for proper startup
  • Protect satellite or TV as well
  • Harmonic analyzer gives complete visibility of your power
"Thank you for the opportunity to test the new Power Center. It's amazing. I notice the improvement in video almost immediately. I have a Samsung 50 inch DLP and on every movie I can see a better picture instantly. On the audio system I have never heard separation between voices like this. Not ever. Thanks."
Tom Edgars
Note: Due to high demand the Quintessence is going back into production. Additionally we've leveraged higher quantities with our suppliers and are now able to offer the Quintessence at an even greater value!
The Quintessence Power Center is the world's first component level AC power center to offer true surge protection, front panel harmonic power analyzer, AC volt meter, remote control and outstanding AC filtering in an affordable shelf or rack mount chassis product.
The Quintessence offers both double common mode and differential mode noise filtering of the AC line, improves performance of connected equipment and provides a safe and noise reduced power source for both audio and video equipment.
Download the Manual: Quintessence Manual
  • Dimensions
  -   17" W x 16.5" D x 4" H
  • Weight
  -   30 lbs
