Call Us: +1 720-406-8946
Network Bridge I
High resolution, gapless enabled, network audio
Built in Boulder
Active promotion: Free 1 year Roon Subscription with purchase
Trade-Up your Bridge I for Bridge II. For a limited time, we are buying back Bridge I. Just select Bridge II with or without a trade in.
The PerfectWave Network Bridge II brings network connectivity to your DirectStream or PerfectWave DAC. Based on UPnP formats, Bridge II can be controlled with any UPnP controller and is able to connect over your home’s Local Area Network via Ethernet (Cat 5). Connect a NAS, computer, JRiver, whatever you have to your PWD or DirectStream.
And now ROON Ready!
More Product Details »
$799.00
Bridge I Network Audio Card
Product Description
The new PS Audio Bridge II makes high-end fun again and connects DirectStream or PerfectWave DACs over the home network. This is the best sounding music input on a PS Audio DAC, better than  even USB. Bridge II offers gapless play, stable performance, lower jitter and the freedom to enjoy digital audio collections, either PCM or DSD, with high performance at the touch of a finger. The Network Bridge II and DirectStream or PerfectWave DAC combo will allow you to build a musical library your friends and family can enjoy for years to come.
With the Network Bridge II installed, you can focus on what you really want: music and the joy of a high-end audio system.
And now, Bridge II is ROON Ready!
  • 192kHz 32 bit compatible
  • PCM or single rate DSD
  • Audible improvement over Bridge I
  • Gapless Playback
  • High speed, low jitter architecture
  • Built in Digital Lens
  • Decodes all popular formats
  • Enables cover art and titles on the DAC touch screen
  • Connect via Ethernet or WIFI (with a commonly available Wifi Ethernet adapter)
  • Easy install
  • UPnP compatible
Audiophilia Bridge II
Karl Sigman
…in the end, ethernet sound quality won me over — whether it be via a 3 feet long cable or 50 feet. And although the Bridge II’s price of $899 might seem steep to some, don’t forget that it is essentially doing, among other things, much of the magic and work that a very high-end music server (costing thousands of dollars) does — and it only weighs a couple of ounces. Quite something–squared. Highly recommended.
Read More
By Karl Sigman, July 18 UPDATE!
We are proud to award the PS Audio PerfectWave Network Bridge an Audiophilia Star Component Award. Congratulations!
Since I awarded the PS Audio MKII DAC an Audiophilia Star, I feel it is imperative to award one to the Bridge, too. The MKII allowed me to rid my system of a $4,000 preamplifier and get better sound. The bridge allows me to rid my system of $400+ USB cables and replace them with $5 ethernet cables and get better sound. Now, that's progress.
Read More
Home Theater Review
By: Brian Kahn, July 15, 2013
"I found the Bridge to provide the best sound, - The inputs are all asynchronous, with the network input accepting up to 192 kHz/32-bit data and the USB accepting up to 192 kHz/24-bit signals. This should allow users to play just about any high-resolution audio file. Most types of audio file will work, including FLAC, WAV, AIFF, ALAC and many more."
Read More
6 Moons
By John Darko, December 2011
"The PWD sounds more engaging, more wholesome when fed ones and zeroes via the Network Bridge (and presumably PWT) than it does as standalone DAC"
Read More
The PerfectWave Network Bridge slides easily into the rear of a PerfectWave or DirectStream DAC and is ready to stream over your network almost immediately. Cover art, song titles, great sound all from this unique network device.
Questions?
Want more product details?
