Power Port™
Awards
Accessories > Power Port™
Power Port More Info1
Starting at just $49.95!
PS Audio introduces the Power Port™, a high-end AV grade AC receptacle available in two styles that can make a significant contribution to your system's performance.
This is a custom built, hospital grade,  15 to 20 amp receptacle that is easy to install either in your home's wall socket or in your Power Plant
These small miracles may just be the finishing touch to any system.
Just a plug?
Yes this is a very cool, nickel plated, hand polished, fire breathing, rapid pulse inspiring AC wall plug, but it is still 'JUST A PLUG!'. No it won't do anything for world peace or the national debt or even help you keep your house clean, but what it will do is create a better connection for your stereo.
You know the one. That same stereo that you spent hundreds of hours scratching your head and reading endless reviews and visiting 5 or even 15 different stereo stores before you purchased each and every component.
Yes, that very same stereo that is right now plugged into a $1.89 mass produced AC wall plug that was purchased at your local hardware store without a single thought as to performance, construction, quality control, durability or power capabilities.
A wall plug that was selected by a general contractor with only the purpose of installing a plug with minimum cost in order to maximize his profit margin so he can buy the parts for his next house.
Why does this matter? Why do you need to consider the importance of this single connection that provides 100% of the power that your system consumes?
Why indeed?
Here's what it's all about
From the day the first Power Plant P300 hit the streets, Audio and Videophiles alike have come to appreciate the importance of 'getting it right' when it comes to AC power.
Power Plants have not only made a major impact on our close-knit community of music and film lovers, but they have also raised the level of performance and expectations for a growing number of people that appreciate great audio and video.
And at the heart of everything we do with AC power is the interface between our equipment and our power sources. The AC receptacle.
Most every home in the US and Canada has a 15 amp duplex NEMA socket in the wall. Some have 20 amp versions, most have 15 amp varieties, but all are basically the same.
During our research into the Power Plants and our continuing research efforts into power quality and what affects the sound and the look of our equipment, the connectivity of the AC socket itself became one of the more apparent issues we had to deal with.
Here is the truth: the quality of home receptacles is pretty grim.
They are constructed out of low grade brass with very little care as evidenced in their purchase price of under $2.00.  They are very poorly built and tend to corrode easily.
We introduce a new receptacle: the Power Port™
Based on our research of existing brands of hospital Grade and Spec Grade AC receptacles, and coupled with what we have learned from reverse engineering the excellent UK receptacles found in England and British wired countries, we concluded that a better plug could be created; one that could make a significant improvement in both performance and longevity.
We formed an engineering and manufacturing alliance with one of the world's leading manufacturers of AC receptacles, Hubbell.
The results of this alliance are significant: we are able to produce a nearly perfect receptacle, and present it to our customers at an affordable price.
It is called the PS Audio Power Port™.
Our first task
Our first challenge was to identify why plugs sounded different. Was it materials? Was it construction? Electrical characteristics? The plastic housing itself?
To find the answers to these questions we purchased virtually every style of plug available. We can generalize their attributes by placing them into three categories:
  • Commercial grade
  • Spec Grade
  • Hospital Grade
The commercial grade plugs are bad sounding plugs, and noticeably so. They can also degrade the video quality of any large screen device. Constructed out of a combination of stamped steel and brass, the ground connections are typically riveted in place, and are constructed of dissimilar materials. These are the type of plugs found in 90% of all North American homes.
We can further narrow the field down by lumping Spec Grade and Hospital Grade together. Spec Grade and Hospital Grade are essentially the same construction, with the exception of contact tension and the plastic housing. Hospital grades have a tested and certifiable tension they maintain on the male plugs. From a practical standpoint, and from a listening standpoint, we find little to no difference between the hospital grade and the spec grade plugs.
The hospital/spec grade plug contacts are typically made from stamped brass.
Upon closer examination
Both the hospital/spec grade plug contacts and the commercial grade contacts are made from either stamped brass or stamped steel, or a combination of the two. Further, if you put these contacts under a magnifying glass, you quickly note two problems detrimental to performance: they quickly oxidize and tarnish, and they are pitted. Oxidation of the brass or steel hampers conductivity over time, and the pitted surface (which resembles a moonscape under close examination) reduces contact area by as much as 40%.
Worse, the combination of pitted surface oxidizing over time creates a 'colony' of metal 'barnacles' that actually become the conducting surface of the contact. Oxidized brass is not very high on the conductivity charts.
Finding a solution
We first considered simply gold plating the contacts of the brass, but quickly rejected that notion when several facts became apparent: gold is soft and will be quickly scraped off of the high spots of the contact area unless a gold plated male plug is inserted, and unless the surface is highly polished beforehand the problem of low surface contact area will not be addressed.
After many hours of consultation with the experts, here's what we learned: if we were to machine the contacts out of solid high purity brass, polish the surface, then nickel plate and polish the surface again, we could achieve our goals of maximum conductivity, high surface area without pits, and prevent oxidation and corrosion over the life of the plug.
This isn't as easy as it sounds
After a number of attempts and rejections, we discovered that this simple idea would take more time and more money to solve. Polishing the brass, followed by nickel plating, followed by another polishing operation produces a very thin coat of nickel and while the surface area is increased, it isn't close to perfect. We eventually settled on 15 separate coats of nickel, and 15 separate hand polishing operations to achieve the desired results.
That's a lot of plating and polishing (we can assure you), but the results are well worth the effort. The PS Power Port™ AC receptacle is, in our opinion, about as good as it gets.
The end result
The Power Port™ is a certifiable Hospital Grade outlet. This means that the contacts have the 'grip of Mickey Mantle' and there's a reduced risk of spark from heavy breathing due to the excitement you'll experience when you audition these outlets -:). Seriously, the Hospital Grade certification is important to insure that the tension is maintained on any male plug that is inserted into the Power Port™.
You can even separate the top and bottom receptacle of each duplex Power Port™. If you want to, you can run a separate dedicated circuit to the top plug as isolated from the bottom plug. This allows the user maximum isolation within the system. Use the top plug for digital, the bottom for analog for example.
The Power Ports are 20 amp ready, but can be used in any 15 amp circuit as well. Due to the construction of the Power Port™, you can run anything from a 10 amp to a 20 amp circuit and be perfectly legal and approved. You can even run a 15 amp circuit on the bottom plug and a 20 amp on the top plug or vice versa.
The Power Ports are completely UL listed and are safe to place in your home.
Easy installation
So what's involved in outfitting your room with Power Ports? Not much. They are incredibly easy to install, and come with complete instructions.
In fact, click here to read a short description of the Power Port's installation instructions.  Easy isn't the word for it!  It's simple!
Turn off the power to the outlet. Remove the cover plate. Remove the two screws affixing the existing receptacle and pull the receptacle out from the box. Using a Phillips screwdriver, simply disconnect the wires from the existing plug and place them on the Power Port™. Reverse the removal procedure and you are done.
What about inside the Power Plant?
We now make an inexpensive kit so anyone can easily upgrade their Power Plant to a Power Port™ equipped version. Power Ports now come as standard equipment on all new Power Plants.
What is the price of the Power Port?
$49.95 each in either the new designer look or the original classic NEMA look... which we feel is a bargain considering what they provide. Not only will the Power Port™ ensure that your system will always be provided with as much power as your listening habits require, but it will also give you peace of mind that your AC wall plug is no longer the weak-link in your power chain. And since Nickel is a precious metal that does not corrode or oxidize, you are guaranteed a lifetime of listening enjoyment without ever having to worry about your wall plugs again!
Pricing for adding Power Ports to your Power Plant
If you want to upgrade your Power Plant to have the Power Ports, the price is slightly lower than buying individual Power Ports. This is true if you are installing Power Ports on an existing Power Plant.  Contact us for pricing details.
Power Ports are shipping almost as quickly as we can keep up with and orders are being accepted through PS Audio's on-line ordering system, or by calling us at 720-406-8946 and of course through your local dealers.
Power Ports are easy to install and are proving to be one of the best improvements you can make for such a small investment of both time and money.
Ready to try one?  Click here.
Power Ports are available in either the stylish new designer model or the Classic model.  Both are 15 or 20 amp ready and both are constructed out of the same nickel plated and polished materials.
Join our newsletter group and get insider information once a month featuring the latest new product information from PS Audio before it hits the street!
Can you receive HTML email?   Yes   No
Email Address:
