facebook_pixel
Call Us: +1 720-406-8946
Power Port Classic 5-pack
Our best value on our purist AC receptacle
Everything we hear and see in our home audio video systems starts as AC power. The better the quality of that power, the better what we hear and see is. Power Ports are high-end AC receptacles no serious music or video system should be without. Easy to install.
$199
Power Port Classic AC Upgrade Receptacle 5-pack
Details
By popular demand we've brought back the Power Port Classic our great and easy improvement to your system's performance. Everything starts at the wall AC outlet and you've got to get it right from the beginning.
The Power Port Classic is our AV Grade high-end AC receptacle that is the starting point for any properly built system. By installing the Power Port AC receptacle in your room you gain an immediate improvement in performance over a standard wall receptacle.
The Power Port is a custom built, AV Grade isolated ground receptacle that will ensure a life-long level of excellence. The Power Port exceeds hospital grade standards for grip strength, contact resistance and current delivery. Easy to install in your wall, this is one component you need in your listening room as it will help make an immediate improvement.
15 coats of polished nickel over high-purity copper, with the “grip of Mickey Mantle” and polished nickel plated hardware, this a must have in your system.
  • 15 coats polished nickel
  • 15 or 20 amp ready
  • Improves images
  • Easy to install
  • Cleans the soundstage
  • Open, airy, top end
  • Improves midrange bloom
  • Will not degrade over time
  • Improved connectivity
  • Lowers apparent noise floor
  • AV Grade
Listening #11
By: Art Dudley • Posted: Nov 23, 2003 • Published: Nov 1, 2003
"All the AC receptacles in my home that feed hi-fi components have now been changed over to PS Audio Power Ports."
Read More
Questions?
