- Can be added to any Power Plant
Easy to install at home
Produces 5 new MultiWaves
Includes TubeWave™
Produces 70 sinewaves
Lowers distortion by 1/2
Adds servo control to any Power Plant
User adjust output voltages
- Fits the power to your equipment
Far better depth
More energy delivered to your power supply
Can be more efficient
Allows you to move beyond the AC restrictions of your Power Plant
A major improvement over the original MultiWave
Now perfect for tubes as well!
Gets rid of transformer hum
"Perhaps, the most interesting observation from the resident cellist is that the she did not need to even be in the same room with the speakers to hear the improvement, and that was just using the default sine wave output.
Bob Tate
Now you can add MultiWave II, servo control and TubeWave capability to any Power Plant model you own.
If your Power Plant does not have MultiWave II, you can literally transform the Power Plant with the addition of this kit.
Easy to install it takes just a few minutes of time and this can be done in the comfort of your home.
Full technical support available if you need, the MutliWave kit brings new life to your Power Plant and provides an unparalleled level of AC performance.
Make sure you have your Power Plant up to the latest standards.
Download the Manual: Multiwave II Installation Instructions
