GCA Power Amplifier
Awards
Stereo Products > GCA Power Amplifier
GCA Power Amplifier Specifications
Starting at just $2,295.00!
PS Audio has never been a big advocate of publishing specifications because they rarely reflect the way a product performs in your system. Customers have judged performance, based on specification comparison, without a working knowledge of how specifications relate to the way a product sounds. However, the opposite has happened as well: some customers will not choose our products because we don’t publish the specs. We decided to go ahead and publish specifications for the GCA line of amplifiers, acquiescing to demand from our customers.
We felt that as long as we’re publishing specifications we may as well include the graphic data from those measurements as well.
PS is a performance based company and as such we believe how a product performs in your system is related to these measurements but these measurements are not the entire story.
Type Digital
Configuration Dual Mono
Class of Operation D
Single-ended Inputs RCA - 1 pair
Balanced Inputs XLR - 1 pair
Input Device Type PS Audio Gain Cell
Input Impedance 47.5 kohms
Input Sensitivity (GCA-100) 1.25V
Input Sensitivity (GCA-250) 2.00V
Input Sensitivity (GCA-500) 2.80V
Output Binding Posts PS Audio w/ Locking Banana Jacks
Output Power @ 8 ohms (GCA-100) 100 Watts
Output Power @ 4 ohms (GCA-100) 200 Watts
Output Power @ 8 ohms (GCA-250) 250 Watts
Output Power @ 4 ohms (GCA-250) 500 Watts
Output Power @ 8 ohms (GCA-500) 500 Watts
Output Power @ 4 ohms (GCA-500) 1000 Watts
Frequency Response (GCA-100) 10Hz - 20kHz
(+0.1/-0.1dB)
Frequency Response (GCA-250) 10Hz - 20kHz
(+0.1/-0.2dB)
Frequency Response (GCA-500) 10Hz - 20kHz
(+0.1/-1.0dB)
THD (GCA-100 @ 1W) < 0.02%
THD (GCA-100 @ 100W) < 0.03%
THD (GCA-250 @ 1W) < 0.02%
THD (GCA-250 @ 250W) < 0.08%
THD (GCA-500 @ 1W) < 0.02%
THD (GCA-500 @ 500W) < 0.05%
Power Consumption @ idle < 40 Watts
Weight (GCA-100) 25.5 lbs.
Weight (GCA-250) 27.0 lbs.
Weight (GCA-500) 29.0 lbs.
Dimensions (W x H x D) 17.25 x 4.00 x 14.00 in.
Join our newsletter group and get insider information once a month featuring the latest new product information from PS Audio before it hits the street!
Can you receive HTML email?   Yes   No
Email Address:
