Call Us: +1 720-406-8946
AC Series Power Cables
Our finest power cables ever
Getting the power from the wall receptacle to your equipment is a critical link that is often times overlooked. The AC Series provide a low noise, low impedance path for the AC power to connect your equipment to either a Power Plant AC Regenerator or the wall outlet in your home. Improvements to both audio and video performance are dramatic.
Clear
Details
Inside the AC Series are three hollow conductors for the treble regions, one massive rectangular conductor for the midrange and multiple gauges bundled together for the bass. Equipment powered with an AC Series power cable enjoy a significant improvement in sound quality over any cable we’ve tried.
  • PCOCC single crystal construction
  • 8 gauge power cable
  • Quad shielded
  • Hollow tube conductors for treble performance
  • Rectangular conductors for midrange performance
  • Multiple gauge conductors for bass performance
  • Gold plated connectors
  • Welded connector to conductor
Construction of the AC12 employs the use of multiple conductor types including hollow core, flat and solid core conductors, plus multiple outer shields properly terminated at only the male end of the cable.
  • Linear Crystal Copper (LCC)
  • 10 gauge power cable
  • Double shielded
  • Nickel plated connectors
Construction of the AC5 employs the use of multiple conductor types including hollow core, flat and solid core conductors, plus double outer shields properly terminated at only the male end of the cable.
  • Oxygen Free Copper (OFC)
  • 12 gauge power cable
  • Double shielded
Construction of the AC3 employs the use of multiple conductor types including hollow core, flat and solid core conductors, plus double outer shields properly terminated at only the male end of the cable.
Questions?
