Oh, the lengths we go to
Prev Next
I have seen some crazy stuff in the 40 plus years I have been around audiophiles and high-end systems. Exotic room conditioning, trinkets aplenty, cables the size of my leg, claims of subatomic effects, components that sound different depending on their earthly orientation, low-frequency waves said to resonate with the Earth. In fact, I could spend hours relating some of the great tricks and techniques applied in service of better sound. What's interesting to me is the large number of these 'tricks of the trade' that actually work. In fact, more often than not fellow audiophiles have taught me great things that I routinely incorporate in my own system and recommend to others. One of those suggestions I often hear about is separating cables from each other. You've no doubt seen the multitude of after-market cones, lifts, and strategies for elevating cables off the floor and separating them from the pack. While I don't currently use these add-ons to isolate and improve performance, I do pay close attention to what sits next to each other. In my experience, higher level cables radiate more than those of lower level. For example, speaker and power cables radiate more than low-level signal cables—yet low-level signal cables are far more susceptible to radiated interference the either of these higher level cable examples. Much depends on levels of shielding and the types of signals being transferred over those cables. My rule of thumb is simple. Do what you can to keep speaker cables off the floor and away from any other cables. (the MG Audio cables I use are easy to simply stand on edge). Power cables are ok on the floor but should be dressed in a way that keeps them from interconnects. And above all, use balanced interconnects at every opportunity. Not only do they consistently sound better, but they can reject stray EMI that does get in. Want more info? I prepared a little video on the subject which you can WATCH HERE.
Back to blog
Paul McGowan
Founder & CEO
Never miss a post
Subscribe
Related Posts
